Air Compressor
Old May 6, 2012 | 08:44 PM
Ajohnson0830's Avatar
Default Air Compressor
I want to put in an onboard air system and I'm considering installing a Viair, but was wondering where everybody is putting the tank. I would prefer to have it out of the way, but any suggestions would be great. Thanks
Old May 6, 2012 | 09:27 PM
JdTms11's Avatar
I’ve got mine mounted between the block and rad fan. ill grab some pics tomorrow. i also made a custom bracket out of aluminum to mount the two compressors above the tank.
Old May 7, 2012 | 02:08 PM
Air Werkz's Avatar
Former Vendor
VIAIR has come out with JK specific kits that are a direct bolt on and include everything you need, along with the wiring harness.
If you have a 07-11, there new 2on2 compressors system is ideal and outs our 4.55 CFM on the 150 PSI system. Also the ADA is a good unit if you are just looking to fill tires and operate air lockers, and not needing to run air tools.
We have a special running for May on both these kits. Just let me know if I could help you out or answer any questions.
May Special: VIAIR JK Specific Kits
Old May 7, 2012 | 05:09 PM
Air Werkz's Avatar
Former Vendor
Yep.... click that link above in my post and you will see it in there.
Old Jun 15, 2012 | 06:17 AM
Ok I've got everything mounted but realized that the kit doesn't come with a hose to attach the tank to the manifold. I have been looking for a heat resistant hose but can't seem to find one anywhere. Any help would be great.
Thanks
Old Jun 15, 2012 | 07:16 AM
jetmechabq's Avatar
look for a local tractor supply and they can make one to fit.
Old Jun 15, 2012 | 07:41 AM
Great thanks
Old Jun 17, 2012 | 01:19 PM
Cet99's Avatar
Thanks
Which system did you end up with?
Old Jun 17, 2012 | 01:34 PM
I got the Viair 2on2 with the JK mounts. I found an air hose at Hydraulic Supply for under the hood, and I love it works great!
Old Jun 17, 2012 | 06:13 PM
Cet99's Avatar
Awesome system.
