Anyone with 35s or 37s on 20s?
My Jeep was bought used with 275/60r/20 tires. I have a four inch lift. How big of tire can I go with no rub? Please post pics of 19s with big tires or 20s with big tires. Thanx Guys.............
You can fit 37s with a 4" lift. Here's the link to the big wheel thread , search is your friend.
https://www.jk-forum.com/forums/jk-s...sh-etc-262394/
Well here goes. Its not you but its the jeep, ok. You have a 4" lift, but did the original owner do the lift 'right'? Do you have aftermarket drive shafts? Control arms? Brake lines? Bump stops? Sounds like you want big tires, but that means a tire carrier too. You may want to look into those things. Going big cost money.
If it was done correctly, then you will have a nice chassis. If your rig will see trails, it may be an idea to go with smaller rims and more sidewall rubber. Not only are tires hundreds less, but it helps save the finish & life of those rims.
