On Board Air using Stock A/C compressor???
#21
sanden a/c compressors can be converted to oba systems, they arnt as good as the YORKS. A quick google search 'sanden oba' will give you a few write ups
#22
#23
#24
#25
#26
Then again, you can always be the guinea pig
#27
the a/c compressor to on board air has been done many many times and it works very well. unfortunatly i cannot post a link cuz it is a competitors forum . go to NAXJA, and do a search there, you will find several write ups on how its done,
#28
i installed a factory ac compressor on my 2012 in the factory location. worked very well until a faulty oiler seized the pump. i plan on replacing it because it was fast, easy and took up no space. a friend of mine has been using the same setup on his cherokee for almost a year now. i did a ton of research on it and the only bad things i've heard were from people that hadn't done it.
