Custom modular JK hardtop
#1681
It would certainly be possible to do it the way you suggest, but I laid it out the way I did for two reasons: first, so you can still access the storage inside the Jeep when the table is deployed up, and second, so things like the StoreGate can be installed on the tailgate and used when the table is deployed.
As for the stove, personally I would prefer to have the stove separate from the Jeep, if only so cooking smells don't fill up the Jeep, so I'd probably want to use something like the Tembo Tusk Skottle - if you're not familiar with it, it's a really cool self-standing, propane-fueled stove that packs up very small for transport and sets up quickly. My Jeep camper friend Donny swears by it.
Maybe if I actually go camping and use this setup I'll have a bunch of different or new ideas about how it should be designed .
#1682
I like the Skottle and want to get one, even if it stays on the porch. I wouldnt want to carry it inside the Jeep, outside on the trailer would be fine. I could strap the Skottle underneath the rear rack on the JK.
For me the back of my JK is all about room for the dog, not storage.
This does give me an idea for a sink off the tail gate table. For the M-PAC I have it could hook into the side of Molle pane in use and store it on the back when the table is up, other tables would need more thought.
I would need to get better water source out back to make a sink work for me. I have 2 gallons in the rear but only get a little better then half gallon out of each while they are mounted. I could always get a second Rubican 10L and mount it behind or to my cooler on the rack and ditch the 2 Rotopax that are there.
Ill post some pictures of what Im thinking when the rain stops.
#1683
A sink could be hooked to the side or front of a tail gate table, like the one I have. It could strap to the table when not in use in the upright stored position. Anyone with the TailGater table or the FrontRunner table could cut their cutting board to drop in a sink, and if they are handy with a router it could slide in when stowed. Or they could have two wooden inserts, one for a cutting board and one for a sink.
You could cut and mount a sink into your StoreGate panel as well.
I could use the same Rockler brackets and some metal to mount a 10L to the top of the rack, as long as the pack is above the sink any mount or rack would do. Or I could just mount it to the cooler.
I just thew it up there to see how it fit. Another Rubican would work better then the 2 Rotopax I have and would give me another .5 gallon of water, and be a lot cheaper.
Looking at it bolting or strapping it to the cooler would work pretty dang good.
#1684
...I could use the same Rockler brackets and some metal to mount a 10L to the top of the rack, as long as the pack is above the sink any mount or rack would do. Or I could just mount it to the cooler.
Attachment 672973
Attachment 672974
Attachment 672975
Attachment 672973
Attachment 672974
Attachment 672975
#1685
Some before and after photos of the fenders. Also showing junk the prior owner installed that I removed, like the light hoop on the front bumper and the air dam on the hood. I also removed the Sahara silver bumper overlays, the Jeep logo on the grille, and I swapped the side steps for rock rails.
The first thing you may notice is the great increase in tire clearance, or perhaps a more accurate description would be that you notice that my stock tires now look too small .
I never realized how big the factory fenders look, to me the new ones look much better proportioned for the Jeep.
The new ones colorized for a better comparison to the body color Sahara fenders.
#1686
Instead of strapping a Rubican to the cooler, why not make a panel like the one I made for the fridge slide? It could bolt to the side of the rack. Here's an idea starter sketch - you could mount it on any side of your rack and the Rubican could be mounted on the outside as shown here or on the inside. You wouldn't have to cut all the slots to make it a Molle panel as I did, all you'd need would be two holes for the Rubican mount.
I would like to put a fire extinguisher on both sides of the rack
The fenders turned out great.
#1687
Thank you very much.
#1688
I appreciated the feedback.
#1689
This is a first for me... I bought an aftermarket styling part for my Jeep. I've never done that before - the JK has no aftermarket accessories at all (I'm not counting the ones I've designed), and the only aftermarket parts on my other two Jeeps are a few suspension parts like 2" spacer lifts and Air Lift 1000 air bag kits. Everything else on all three of my Jeeps I designed and built myself.
I've been thinking the factory front bumper looked too long with the flat fenders:
So I bought a VDP stubby bumper kit. The modification of the factory bumper and installation of the VDP ends was a quick and easy process and I think the mod looks perfect with the flat fenders.
#1690
I was waiting to see what you'd come up with for that bumper. I like that everything on your vehicle is neatly put together as though it could have come from the factory like that.
