"Ef"s-Pod
Old Jul 27, 2008 | 05:28 PM
zoomzoomjr's Avatar
Default "Ef"s-Pod
01110111011101110111011100101110011010100110101101 10111101110111011011100110010101110010011100110010 11100110001101101111011011010010000001101001011100 11001000000110110101110101011000110110100000100000 01100010011001010111010001110100011001010111001000 10000001110100011010000110000101101110001000000111 01000110100001101001011100110010000001110011011010 01011101000110010100101110001000000100011001010101 01000011010010110010000001010100010010000100010101 01001101000101001000000100110101001111010011100100 01010101100100100000010010000101010101001110010001 11010100100101100100100000010000100100000101010011 01010100010000010101001001000100010100110010000100 10000100100001
Last edited by zoomzoomjr; Aug 12, 2009 at 09:41 PM. Reason: Blacklisted manufacturer
Old Jul 27, 2008 | 05:53 PM
zoomzoomjr's Avatar
It is one of those, and it is supposed to be "100% Airtight & Watertight". I was looking for something that sat next to the battery, and was about 6 x 9 x 2, and it fit the bill. As far as the name, I updated my first post.
Old Jul 27, 2008 | 05:56 PM
User 12721's Avatar
Just a suggestion...you may want to drill small holes in the bottom of the box, or fill around the holes of the fuses/wires/relays that you cut out of the box with clear silicone, since if any water ever gets in there it isn't getting out that easily!
Old Jul 27, 2008 | 06:05 PM
mikeyfl's Avatar
nice work... worthy of the backyard builders fair?
zoomzoomjr's Avatar
I was thinking about doing one of those, or even an LED alert on the dash that is hooked up to a water sensor inside the container.
Edit: Not yet Mikey. Still not 100% done, but VERY close.
Old Jul 27, 2008 | 07:00 PM
deconstructionist's Avatar
Cool deal & thanks for the PM
Old Jul 28, 2008 | 04:25 AM
riverzendz's Avatar
Very nice work! Just a thought here. They (home improvement stores) sell out-door utility boxes that are plastic, water-tight, and inexpensive. That may be a better solution for a housing but I do like what you have done.
Old Jul 28, 2008 | 05:54 AM
SASQUATCH's Avatar
Like it, alot, I'm not sure of the container, heat/cold, elements, tend to make that particular plastic brittle over time, but the rest of it is pretty awesome. I'd consider RTV as pre-mentioned by others to seal the wiring holes. Great work
So how much is an S-pod anyway?
Old Jul 28, 2008 | 08:11 AM
Ok- so now for the big questions...
WHERE did you get all these parts? And do ya' still have part numbers??????
Old Jul 28, 2008 | 09:12 AM
SASQUATCH's Avatar
Originally Posted by TBJK
I saw a spod fom 4x4spod.com for like 450 bucks...freaking expensive man. i believe i will build my own
wow....yeah....so we need part #'s now
