Old Mar 21, 2014 | 01:03 PM
  #3621
Mark Doiron's Avatar
Just received an e-mail from OTRATTW where I bought the custom toggles for my sPOD controller. It appears that he has restocked some of the colors he was out of. This applies only to the Contura II toggles--Contura V toggles he laser-engraves on demand. The Contura II toggles are silk-screened, so won't backlight like the Contura V. But, they look more consistent with the older JK interior ...
Name:	Jeep Work, Sep 13, 5_9826, Engine Fan Switch.jpg
I will be switching out the roof and driving lights toggles for amber.
Old Mar 21, 2014 | 07:18 PM
  #3622
PFTWHFTB's Avatar
Here's one partway built and a brand new one waiting to be built on.
Old Mar 25, 2014 | 09:00 AM
  #3623
Cool Danish's Avatar
Default Custom Tire/Rotopax gas can carrier.
I have been working on a custom Rotopax gas can carrier, using my existing tire carrier swing arm from my Expedition One rear bumper.
Just got the swing arm back from the powder coater and can finally install everything on the Jeep this weekend.
Here is how it will look (before powder coat):
ID:	540444Click image for larger version
ID:	540445Click image for larger version
Here is the parts back from powder coating (they matched the bumper color and texture perfectly):
ID:	540446Click image for larger version
Here is a video that shows the carrier in little more detail.
http://youtu.be/iEbEePN5d1Q As you can see in the video, the two 4 gallon Rotopax cans are locked down with a padlock (Which is keyed to the Jeep key).
The two hand knobs are for tightening down the cans, so the do not rattle/move while driving.
I also retained the original 3rd brake light, made provisions for mounting rear backup camera (middle/below tire), floodlight pole bracket & water proof dual 12V outlets.
Old Mar 25, 2014 | 09:10 AM
  #3624
toxicity_27's Avatar
Attachment 540444Attachment 540445Attachment 540443
Attachment 540446Attachment 540447
Very nice work!
Old Mar 25, 2014 | 09:55 AM
  #3625
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
To the guys using power inverters:
I had a recent stroke of genius, about 15 minutes after I bought the power inverter I plan on putting in my Jeep. I have a small obsession with using ammo cans for projects, and this is no exception. I plan on mounting the inverter inside an ammo can (since it's waterproof), and hardwiring it to the battery with a switch in the line to turn it completely off, so it doesn't kill my battery when the Jeep is off. I'm going to use rubber fittings and shrink-wrap to waterproof the holes that I will drill in the can for the positive and negative wires. Hopefully I'll get to it this weekend. If I do, I'll post up a small writeup when it's finished.
Old Mar 25, 2014 | 10:13 AM
  #3626
I would try out the inverter under load while in the ammo can, just to see if the inverter can get rid of the heat.. Most inverters (higher wattage) rely on air convection around the cooling fins. It might just get so hot that it will use the build in thermal shutdown.
Anyways, something to check before putting lots of work water proofing and mounting the ammo box.
Old Mar 25, 2014 | 10:26 AM
  #3627
jr24jku's Avatar
We started onto dirt roads directly out of the VLA heading south on 52. I can send you a .gpx of the route we took which you can drop into Google Earth, if you're interested. PM me an e-mail address. Because of the deeper snow than expected at higher altitudes, and because of a problem with my tent (okay, it's actually a long story, but it was my fault that while the tent was in NM, the poles were in OK, LOL), we ended up changing our itinerary and spent less time in the backcountry than we wanted. We had also planned to drive through Monticello Canyon, but didn't make it. And on the last night forecast was for snow, and since three of the folks had to get back to work in Texas the day after, several of our group didn't want to risk getting stuck in the backcountry that last night. Here are a few more pictures ... Yep, this is me ...
What type of roof rack do you have ? I'm trying to find a roof rack that would work with my snorkel.
Old Mar 25, 2014 | 10:53 AM
  #3628
He has the MBRP rack. He modified one of the front legs to get the snorkel to fit better, also I believe the rack only fits 07-10. Correct me if I'm wrong Mark.
Old Mar 26, 2014 | 05:59 AM
  #3629
Gforce!'s Avatar
I did think about that, and the only time I need it to be waterproof is when the jeep is in motion. I'm really only planning on using it to run power tools (in case of trail breakage or something), so I think it'll be fine when I'm using it, because I'm not going to build it in such a way that it can be used without the top of the ammo can being opened. I think since the lid will be up, it wont have any problems venting, but you may be right, it's definitely a possibility. I appreciate the forward thinking.
Old Mar 26, 2014 | 06:06 AM
  #3630
Here's more info on how I made that work ...
https://www.facebook.com/media/set/?set=a.4378461420621.2158281.1260697505&type=1&l=8 7ad61e5da
As for that rack (with optional extension and basket) fitting the later JKs: I'm not sure. The windows on the hardtop are larger, which makes the one I have incompatible. I don't know if they ever redesigned it to accommodate the larger glass. It is from MBRP/Off-camber Fabrications. I bought mine through Amazon, which meant free shipping.
