Hardtop top surface painted white
Old Oct 29, 2010 | 07:35 PM
Patchules's Avatar
Default Hardtop top surface painted white
Here are some pics of my hardtop after being painted with Bus Kote, a paint for reducing heat from the sun on RV, school bus roofs etc. I did my 05 Unlimited with a white material I had left over from painting the metal around the roof of my old building. The Bus Kote was easier to apply and reduced the heat inside.
ID:	99209   Click image for larger version
ID:	99210   Click image for larger version
Old Oct 29, 2010 | 07:44 PM
kittisman's Avatar
Links don't work.
Old Oct 29, 2010 | 11:56 PM
coastie kyle's Avatar
Veteran: Coast Guard
No workie. But I want it too
Old Oct 30, 2010 | 08:45 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Links dont work.
Was this put on the inside or outside?
Checking the website for this, which product number was used for this?
Thanks.
Old Oct 30, 2010 | 03:33 PM
Patchules's Avatar
Default Products
I used Bondit, #1220 and Bus Kote, #2150 from Hy-Tech. The primer is very watery like. Seems to stick well so far but I don't plan on running the JK thru the Jeep Wash.
The Bus Kote was put on in 3 thin coats with a brush for 2 and roller for 1 coat. I may add another coat to make it look a little smoother. it can be sprayed which would have made it look better close up. I notice the white roofs now on all the school buses.
Sorry about the pics, they worked first time. Must be doing something wrong in Manage Attachments so they may disappear again. If so I will add them to my Picturetrail acct.
I have plenty of Bondit and some Bus Kote if someone in Baltimore area wants to buy some cheap. Send PM.
Old Oct 30, 2010 | 08:58 PM
JKid's Avatar
Sponsoring Vendor
Epic-Addictions Representative
You've successfully turned your JK into an FJ!!! I'm sure there is a huge difference in temps.
To reduce heat in my JKs I installed speaker carpet from Walmart on the ceiling of my freedom tops. Works great in the summer when it doesnt get below 110 for weeks at a time!
Old Oct 30, 2010 | 09:01 PM
shockwaveaz's Avatar
To reduce heat in my JK I installed speaker carpet from Walmart. Works great in the summer when it doesnt get below 110 for weeks at a time!
That's funny
Sent from my EVO using Tapatalk.
Old Oct 30, 2010 | 09:18 PM
DCJEEP's Avatar
Got any photos of the complete jeep? Not my cup of tea but then again it's not my jeep!
Old Oct 31, 2010 | 07:15 AM
donnie's Avatar
Thanks for the info.
I like the way it turned out.
Iv considered changing the whole top to white from the black on mine, or at least the roof part only.
Old Oct 31, 2010 | 07:22 AM
Patchules's Avatar
I will take a pic when it is parked on the street. Never had to have a reflective top when I lived in Lac-Saint-Jean region. Lots of sun but that only helped melt the ice!
