Help. . .
Old Jul 6, 2011 | 01:08 PM
Mikey214's Avatar
Default Help. . .
How can I remove this stupid dealer decal without screwing up the paint of my jeep??
Old Jul 6, 2011 | 01:12 PM
Orangeav's Avatar
If it's a raised logo, get some dental floss and slowly slide it in behind and cut the backing away. If it's just a sticker lift a corner and pull it off.
Old Jul 6, 2011 | 01:21 PM
Mikey214's Avatar
Originally Posted by Orangeav
If it's a raised logo, get some dental floss and slowly slide it in behind and cut the backing away. If it's just a sticker loft a corner and pull it off.
It's a raised logo
Old Jul 6, 2011 | 01:26 PM
Mikey214's Avatar
Dental floss is not working at all
Old Jul 6, 2011 | 01:29 PM
Swooper's Avatar
did you try to heat it up at all? around the outside, then try floss?
try and slip some goo gone in there?
pettym's Avatar
Use a heat gun on a low setting. That should losen up the glue enough to pull it off. I did that to all the decals/logos on mine and it didnt ruin the paint at all
Old Jul 6, 2011 | 01:32 PM
BadPunkin's Avatar
Heat gun and fishing line worked for me
Old Jul 6, 2011 | 01:48 PM
Mikey214's Avatar
Dont have a heat gun, will a blow drier work ?
Old Jul 6, 2011 | 01:51 PM
pettym's Avatar
It might, no guarantees. They aren't that expensive and do come in handy though.
Old Jul 6, 2011 | 01:53 PM
Swooper's Avatar
will prolly take a little longer, but yeah... dont hold it in one spot too long, though...
work it around. and good point - fishing line is stronger than floss to push its way through.
edit: take it back to the f'n dealer and tell them youre not advertising for them
