Maertz's Half Ass Build Thread
Old 04-24-2014, 05:24 AM
  #261
Maertz's Avatar
Well I have been looking into running a single triangulated front and have only found one guy that has done it, i am wondering if this may be a bad idea, from my understanding it isnt a bad set up but I would assume its putting more stress on the mounts? Anyone have any more info? In the meantime I am just waiting a few days on parts so just tossing around some ideas.
Old 04-24-2014, 05:42 AM
  #262
Ringer's Avatar
If you are doing it to get rid of the track bar, you need to run full hydro(can't remember if you were or not).
Old 04-24-2014, 05:44 AM
  #263
Maertz's Avatar
nope i am only assist. and yeah thats my pain in the ass at the moment is the track bar. I guess ill have to get creative.
Old 04-24-2014, 06:25 AM
  #264
TheDirtman's Avatar
Same thoughts here. Full hydraulic steering. Break a line or have engine trouble=no steering.
Old 04-24-2014, 01:58 PM
  #265
Maertz's Avatar
yeah i will be keeping assist for that reason. Dirt any chance you have a pic of your front frame side link brackets? I looked around and couldnt find any.
I should be able to figure it all out link wise, but the trackbar is where i need to get creative. Where my axle sits and where the trackbar goes is right where the steering box is located forward, and i would lose uptravel with this huge truss as the bracket hangs down damn near to it. I could go behind the axle but the upper link will be over there so i would have a short trackbar..
Old 04-24-2014, 02:06 PM
  #266
TheDirtman's Avatar
Control arms?
Old 04-24-2014, 02:17 PM
  #267
Maertz's Avatar
Originally Posted by TheDirtman
Control arms?
Yeah sorry. the front control arm frame mounts. Id also look at the trackbar frame side to if you had a picture. I should be able to figure it out, but any other ideas are a big help also. It might not be as bad as im thinking i just need to get my last brackets in so i can see a little better what im working with. You know how that goes im sure.
Old 04-24-2014, 02:39 PM
  #268
TheDirtman's Avatar
I just have a 3 link front.
ID:	548174Click image for larger version
ID:	548175Click image for larger version
Old 04-24-2014, 02:41 PM
  #269
Maertz's Avatar
yeah ill have to do a 3 link also. The control arms are damn near exactly what i was picturing..a was also contemplating the frame brackets for my lowers then another one in front of those and higher up for the upper, but i would lose separation. that trackbar bracket fit nicely in there, but my truss hangs up so high i believe it will limit me.. I appreciate you taking the time to help me out though. When i get my trackbar bracket in I will have to see what i can work out.
Old 04-24-2014, 02:45 PM
  #270
TheDirtman's Avatar
Yes, that is one of the issues of trusses and tall brackets bridges like rear 3 links run into. Just going to a dana 60 front causes clearance issues over the dana 30 or 44.
