My homemade door cart
So after seeing this for $159.99...
I decided to make my own.
$50 dollars said and done. One more reason to take the doors off! (I don't have a garage which would have made things easier storage wise.)
Thanks! Not much to it...all Home Depot parts. I got the wheels (~$4.60, x4), wood (spray painted it black), 2 L-brackets (x2), and 4 rubber stoppers w/screws (attached to edges of center beam where the door touches) all at the depot. Also, those rubber pieces at the bottom are for house doorways to keep air/water out (~$5.00 a piece). I can't remember the dimensions but I just made sure it was wide enough to fit the door longways and wide enough to let the doors lay against the center beam.
nice job!!!
I have the one in your first picture... Funny thing is when I ordered that cart last year it was listed for use with the '07 JK. But I've noticed that they no longer have the JK's listed on it. And I know why- the little "channel" that you set the doors into are too close to the center. So when you put the first door in, you need someone to stand there and hold it while you deal with the 2nd door. Also, the pictures and instructions have the velco strap wrapped around the top of the doors. But the tops of the JK doors are way too far apart to use that velcro strap. However, the velcro strap will reach the handles, so I just wrap it around the handles to hold the doors in place.
Needless to say, I'm betting your cart works better! Maybe you should sell them in the basement builders.
while i was shoveling a foot and a half of snow yesterday, i was thinking about building something like this this spring.
does anyone else have any other ideas that would work. i have an unlimited, so i am wondering if it would make sense to make one rolling rack for the front doors and one for the rear doors. it would probably be more manageable to roll into my shed than one rolling rack with 4 doors on it.
