Nemesis Took Over the SEMA Show!
Sponsoring Manufacturer
Thanks!
I'll talk to the team, but the reality is that the pricing is accurate for a completely American made product that fits this well, performs this well, and looks this good.
Originally Posted by Nemesis Industries
Here's a quick comparison pic showing the different front flare options we have for JK's.
Wiring of the LED marker light is a quick solder or butt connector (2 wire to 2 wire) whichever you prefer.
The front inner fender liner will require a tape measure to mark and then a razor blade or cutoff wheel to trim. Install of the front flares should take no more than a few hours.
The rears are actually easier than the fronts since there are no additional holes to drill. We do however, have to use nutserts since some of the holes go into blind cavities. To make the install of the nutserts easier we supply a simple nutsert tool along with the hardware kit. You will want to use some Locktite on the nutserts to help hold them on the body (we do this on all installs completed at our facility). Hold the flare to the Jeep mark the holes that ned to be enlarged, drill, instal the nutserts, and bolt on the flare. You can trim and re-install the rear inner fender liner if you wish however, most do not. A can of rubberized undercoating or black spray paint does the job.
We designed our flares to fit perfectly with 40" tires, so if you are running larger tires you can actually use the rear flares as a guide for trimming the sheet metal. a recip. saw or cut off wheel works great here. A small trim for 37's since you only cut off the pinch seam or a large trim for 40's.
We work very hard to ensure the precise fit of all of our products. Our attention to fitment makes install a breeze for shops and the weekend warrior.
Thanks,
Rob
