New Tires! 315/75R16 Goodyear Duratracs
Old Oct 17, 2010 | 05:28 AM
ShiftySooner's Avatar
I've got the same tire and love them; I know you will too. I've beat the crap out of them, and they look no worse for wear. Great on-road ride, too.
What size rim are you running? I've got a 16x8, and at 30 psi they mearsure 34" exactly. However, the track width of the tire is a bit narrower, only about 10.5" of the tire actually meets the road. If you have a wider wheel, it will stretch the tire out a bit, but give you a slightly shorter overall height.
Either way, looks great on your JK man!
Old Oct 17, 2010 | 05:39 AM
Yamaha90's Avatar
Thanks!
I'm running 315/75R16 Duratrac, on a 16x8 wheel as well. the treadwidth looks to be the same width as my terra's which were around 10 of tread width. I do love these tires though. They're sick.
Old Oct 17, 2010 | 07:43 AM
lowe516's Avatar
Default good choice
Nice set up! Im jonesing hard for some new tires myself
Old Oct 17, 2010 | 09:39 AM
vinnysucks's Avatar
Would the 325/75R16 be 34" ?
Old Oct 17, 2010 | 09:44 AM
Enzo's Avatar
Specification Sidewall Radius Diameter Circumference Revolutions Speedometer Odometer Difference
325/75-16 9.6" 17.6" 35.2" 110.6" 573/mi 60MPH 10000mi N/A
its 35.2 inches
Old Oct 17, 2010 | 09:48 AM
vinnysucks's Avatar
its 35.2 inches
Does that same source read 34.5" for the 315?
Old Oct 17, 2010 | 09:56 AM
Enzo's Avatar
315/75-16 9.3" 17.3" 34.6" 108.7" 583/mi 60MPH 10000mi N/A
Yes it does.....I use this website www.powerdog.com
It has a tire calculator
Old Oct 17, 2010 | 10:10 AM
Stuka's Avatar
Tire sized are measured with no weight on them. If you are measuring them with weight on them, you have to go side to side. Not ground to top. As there are way to many variables measuring ground to top, which is why manufactures don't measure that way. Also, a wider rim will make the tire shorter than a narrow rim. And of course the lower the air pressure, the shorter they are.
And as a last note, *very* few 35x12.50LT tires measure out to be 35" tall. Almost ALL of them are 34-34.5" tall. There are a few exceptions, typically Interco tires measure the right size or larger. A 33x12.50R15 TSL is actually 33.7" tall for instance.
But you tires look great, and should drive nicely
Old Oct 17, 2010 | 10:35 AM
vinnysucks's Avatar
Hmm so if the 315 was giving OP a tire just over 33" then maybe he would be happier with the 325 which I am assuming would be between 33.5 and 34 inches mounted on his setup.
Old Oct 17, 2010 | 10:37 AM
JKMudder's Avatar
They dont make the tires in a size bigger than the 315/75R16s.
