no lift on 35's
Old Jan 27, 2010 | 02:42 PM
Default Official no lift/1" or less lift on 35's Thread
Requirements:
-Your lift can't exceed 1"
-Flares, no flares, tube fenders, cut flares doesn't matter.
-We're lookin for pics and experiences you've had w/ your fenders/flares.
-It's ok if you no longer run this way anymore.
Let's see em.
Old Jan 27, 2010 | 03:46 PM
westchester's Avatar
Don't do it, I have old photos in my gallery without life. Ill post more details + photos tomorrow, I'm on cell phone right now
Old Jan 27, 2010 | 05:04 PM
Locklain's Avatar
35's with no lift at your request.
Old Jan 27, 2010 | 05:20 PM
You WILL rub on the rear body with 35s. Mine was like below for short time, it was fine when alone, but it did rub with buddies aboard, and rubbed with axle articulation.
Also my (supposed) 35" MTZs only measure 33.75" diameter at 29psi, so I got away better than many other (supposed) 35" Mud tires (which in reality measure 34-35").
no lift, no fender chop
no lift, with fender chop
Old Jan 27, 2010 | 05:21 PM
pinch seam also needs to be bashed or cut with 35s
Originally Posted by Locklain
Old Jan 27, 2010 | 06:52 PM
Locklain's Avatar
It was only for demonstration purposes. I had the tires sitting in the garage and I needed to rotate my old set so I threw on the 35's just for a few shots. I have since been lifted.
Old Jan 27, 2010 | 10:07 PM
silvurback's Avatar
mine through a few different stages. all stock on 35's....
35x13.50x15 BFG Krawlers
no fenders...
35x12.50x15 BFG KM2's
Old Jan 28, 2010 | 02:50 AM
JeepNumber5's Avatar
I'm still runnin' 35s, but only had them on for day with the stock flares before slapping on some xenons. I've got a set of 0.75" spacer that are going on when I get back from deployment. All of my pics are in the gallery (stock, 35s, flares, etc).
Old Jan 28, 2010 | 07:09 AM
Perfect, I'd like to make this an official no lift or lift under 1" thread as I'll be removing the flares on mine and cutting the fenders up slightly.
I'm in high hopes that rev111 now known as metal cloak will come out with some arched tube fenders.
or I may get some OKE tube fenders. (overkill engineering)
Old Jan 28, 2010 | 07:15 AM
more here 35s no lift : https://www.jk-forum.com/forums/show...t+flat+fenders
