Plasti dip / painted wheels black
Old Apr 30, 2012 | 08:55 AM
  #31
MDPJeep's Avatar
WOW - Very nice !!!
Old Apr 30, 2012 | 06:58 PM
  #32
74CJ5's Avatar
My JK already has black wheels, but I did do the Mustang this weekend.
ID:	311184   Click image for larger version
Old Apr 30, 2012 | 07:00 PM
  #33
jfleur91's Avatar
Originally Posted by OhhSeven
Yeah no issues at all. I've had a couple of wheeling trips in and they seem to be holding up just fine. Only areas to have issue at this point are around the seats for the lugs as I've rotated the wheels twice since then.
Yeah I can see that happening. It must be tricky to mount them back on without twisting the bolts... which would peel the plastic. But if it works.... then hey... it works
Old May 1, 2012 | 05:34 AM
  #34
aekdbrich's Avatar
I definitely want to do this, but I don't wanna deal with a lot of reapplication. I've been really hesitant and I really want to see these in person! Someone come to Charleston!
Old May 1, 2012 | 05:48 AM
  #35
stevefields's Avatar
Originally Posted by Napalm
I'm having problems with parts of mine not sticking and making bubbles...its pissing me off because it makes my steelies look so good!!!
What did you clean them with before you sprayed them.
Old May 1, 2012 | 07:40 AM
  #36
Napalm's Avatar
I used windex. I peeled it off and did them again and now they are sticking.
You guys ever tried to power wash this stuff?
Old May 1, 2012 | 08:45 AM
  #37
Redman333's Avatar
If they look good black you should go ahead and just paint them. I think this product is really good for those that are not sure it's going to look good and want to test the color out. If your having problems with bubbles with this product go ahead and paint it.
With that said if you want to use plasti dip still then I'd try to strip everything back again and clean the wheel really good with alcohol and dip them in a controlled temperature around 70 degrees and low humidity.
Old May 1, 2012 | 10:23 AM
  #38
I used bedliner spray on mine.
Old May 1, 2012 | 02:49 PM
  #39
Camojeep's Avatar
Do you need to paint (Plastic Dip) the backside of the wheel?
Old May 1, 2012 | 04:04 PM
  #40
Jdell68's Avatar
Just did mine yesterday, they came out great...
ID:	311666 Click image for larger version
