Prodigy Performance Turbo Install On 2011 Sahara 6 Speed
#71
I just pulled the trigger On Prodigy's 12 PSI kit.....Can't wait to make the simple mods and grab another 40 Rear Wheel HP
G
#73
#75
Well......Prodigy's Standard kit is forcing 8 PSI worth of Air/Fuel Mixture into the Motor......The Next level is thier 12 PSI....Its a prtty simple mod.....should only take me about
2 hours to install. Prodigy Performance is a Vendor on this site....you can look them up under the vendor section or Jump on thier face book. Let me know if you need anymore help!
G
#76
G
#77
What?????? 4K to build power???? I'm not sure what you're looking at but you build HP just as the factory motor did.....Only a _hit pot more!
After all my Offroad mods...My Jeep was about useless....Till I added the 150 RWHP from the 8PSI kit......Its an all around vehicle now....Great on the Freeway,
Killer Off Road and a pretty good stump puller when I need it! I guess you haven't seen the Factory HP Curve.
What are you looking to do with your ride?
#78
We need more of these installs out there. 4k rpms to build power? Look at the dyno curve. Do the research. Why do you suppose diesel trucks use turbos? They can't even get to 4k rpms. It's all in the sizing of the turbo. 03HDFB, how did it run on the 87 octane? Any ping? I'm curious because that is a sure indicator that it is a safe combo.
Thanks for some real world insight.
#79
#80
http://prodigyperformance.com/wp-con...12/01/Dyno.jpg
Seems like it really starts to kick around the 3k to 4k mark
