Project-JK's NEW 2012 Dozer JK Unlimited Rubicon - RubiCAT
Old Apr 11, 2012 | 08:19 AM
  #321
wayoflifette's Avatar
JK-Forum Founder
Originally Posted by Superbad
Just curious but what is the point if any in spending the extra money for a rubicon if you tear everything out that makes it a rubi? wouldn't it be cheaper/smarter to just buy a unlimited x?
Originally Posted by rcdude3
RubiCat still has all the Rubi parts. Front and rear 44 and the 4.1 T-Case...for now. The front axle has the EVO "C" gussets. The main thing changed is the suspension.
As rcdude3 pointed out, RubiCAT still has all the rubicon parts and if/when we do upgrade the axles, we can sell the 44s to help fund 60s. Also, the rubicon has certain things we wanted that we couldn't get on an x like the electronic sway bar disco, the 4:1 transfer case, and the upgraded NAV stereo. To this day, Moby is still running the rubicon transfer case and the sway bar disco.
Old Apr 11, 2012 | 08:24 AM
  #322
shag7265's Avatar
Originally Posted by Andrew@EVOMFG
No exhuast clearance issue. A front aftermarket driveshaft solves this with pretty much any lift or wheel travel we have seen so far on 2012s. A MUCH better option than spacers or relocate. Driveshafts give the clearance that you need and added driveline strength.
EVO Protek skids stayed without issue, except the exhaust skid which will not work with long arm kits, but the EVO Oil Pan and Transmission Skid are no issue. Works perfect with the kit.
Andrew
EVO MFG
714-879-8913
Andrew, so there is no need for spacers or extensions if I get an aftermarket front drive shaft ?
Old Apr 11, 2012 | 08:32 AM
  #323
MTG's Avatar
MTG
Shag:
I am sure Andrew will jump in here but I have the EVO Enforcer kit which is an approx 4" lift and the EVO Protek skids on my 2012. The aftermarket front DS works perfectly without any need for modifying the exhaust (i.e. no spacers).
Old Apr 11, 2012 | 08:33 AM
  #324
shag7265's Avatar
Originally Posted by MTG
Shag:
Awesome, thanks.
Old Apr 12, 2012 | 07:26 AM
  #325
JK-Forum Founder
Here are a few updates to the build...
Got the new Truck-Lite LED Headlights installed on RubiCAT!
Here is a pic of the new Truck-Lite LED headlights with low beams on:
EVO 1/4 pounder bumper installed:
All cleaned up and ready for an ATX Wheel photo shoot at Off Road Evolution:
Cut fenders installed...
Old Apr 12, 2012 | 07:27 AM
  #326
JK-Forum Founder
On the Friday before Moab EJS, Off Road Evolution finally got in the new EVO spec King coilovers that we had been waiting on to finish up their bolt-on coilover system. Below are some of the pics of the final install:
The new EVO spec King coilovers
The EVO upper reinforcement brackets for the rear coilovers
The complete rear EVO bolt-on coilover system - upper reinforcement brackets, rockstars and EVO spec King coilovers - Yes, it really is that simple!
Installing the rear coilovers
You can see the upper brackets just above the frame
The rear is finished
The new King bumps for the front
Cutting off the factory bump stop so that the new King bumps can be installed
The front with the new King bumps installed
Tires back on and ready to hit the ground
Testing out the EVO flex!
Old Apr 12, 2012 | 08:11 AM
  #327
JKRay's Avatar
Its looking sweet!! So how do you like the new truck-lights?
Old Apr 12, 2012 | 04:28 PM
  #328
wayoflife's Avatar
JK-Forum Founder
honestly, i like the look of the old style lights better but in terms of performance, these work just as well
Old Apr 12, 2012 | 04:29 PM
  #329
wayoflife's Avatar
JK-Forum Founder
Okay, just got Rubicat all cleaned up and painted the fender wells. Here are some poser shots of what it looks like now...
Old Apr 12, 2012 | 04:35 PM
  #330
Stuff's Avatar
Rubicat looks awesome!
