Project-JK's NEW 2012 Dozer JK Unlimited Rubicon - RubiCAT
To this day, Moby is still running the rubicon transfer case and the sway bar disco.
Originally Posted by Andrew@EVOMFG
No exhuast clearance issue. A front aftermarket driveshaft solves this with pretty much any lift or wheel travel we have seen so far on 2012s. A MUCH better option than spacers or relocate. Driveshafts give the clearance that you need and added driveline strength.
EVO Protek skids stayed without issue, except the exhaust skid which will not work with long arm kits, but the EVO Oil Pan and Transmission Skid are no issue. Works perfect with the kit.
Andrew
EVO MFG
714-879-8913
I am sure Andrew will jump in here but I have the EVO Enforcer kit which is an approx 4" lift and the EVO Protek skids on my 2012. The aftermarket front DS works perfectly without any need for modifying the exhaust (i.e. no spacers).
Originally Posted by MTG
Shag:
Here are a few updates to the build...
Got the new Truck-Lite LED Headlights installed on RubiCAT!
Here is a pic of the new Truck-Lite LED headlights with low beams on:
EVO 1/4 pounder bumper installed:
All cleaned up and ready for an ATX Wheel photo shoot at Off Road Evolution:
Cut fenders installed...
On the Friday before Moab EJS, Off Road Evolution finally got in the new EVO spec King coilovers that we had been waiting on to finish up their bolt-on coilover system. Below are some of the pics of the final install:
The new EVO spec King coilovers
The EVO upper reinforcement brackets for the rear coilovers
The complete rear EVO bolt-on coilover system - upper reinforcement brackets, rockstars and EVO spec King coilovers - Yes, it really is that simple!
Installing the rear coilovers
You can see the upper brackets just above the frame
The rear is finished
The new King bumps for the front
Cutting off the factory bump stop so that the new King bumps can be installed
The front with the new King bumps installed
Tires back on and ready to hit the ground
Testing out the EVO flex!
The front axle has the EVO "C" gussets. The main thing changed is the suspension.
So how do you like the new truck-lights?
