Rear diff breather relocation
I know this has probably been covered 100 times, but sometimes it's nice to see things again and maybe a different way of relocating it...
I just did this a few minutes ago, hope it helps....
9/32 vaccum hose with 3/8 vaccum connector. I added on without replacing factory hose. Zip tied it to E-brake line and frame and ran it up through frame into rear driver tail light so it would not catch on anything...
The connector is up in frame and I sealed connectors (aftermarket/factory breather) with electrical tape just for precautions...
I also left about a 1 1/2 feet of flex or more, just in case I need to modify it at some point...
If I recall correctly the penetrations in the tub behind the taillights have grommets in them that the wiring passes through with a rather tight seal. This should preclude any exhaust gases or newly found axle breathing in to the cab from that area.
So when are you doing mine? We gotta get the transfer case relo'd too. The line comes up over the transfer case and swoops driver side on the transmission.
