salvaged Dana 60's - JK brackets?
Old Jan 23, 2009 | 05:51 PM
Awesome! Thank goodness for aftermarket parts. You guys are on the ball. The plan is unfolding.
WOuld the ESP and BAS system work with these components?
Old Jan 23, 2009 | 07:00 PM
dyolfknip's Avatar
You might be in a little bit above your head. See if you can find someone local who knows what they are doing. Brackets cannot and will not affect the computer issues you are going to run into.
Old Jan 24, 2009 | 08:16 AM
That is correct, which is why I am here getting advice.
Old Jan 24, 2009 | 07:32 PM
David @ Currie Ent.'s Avatar
Former Vendor
Yes, it will work as long as you re-use your factory brakes.
Old Jan 25, 2009 | 03:43 PM
ROCKSTAR27's Avatar
Nice stuff David
Old Jan 25, 2009 | 07:28 PM
muddpuppy01's Avatar
Originally Posted by David @ Currie Ent.
If you are interested in putting your own 60 together we have everything you need.
Axle Shafts
http://www.currieenterprises.com/CES...6.aspx?id=3371
Mfg: CE-1014PJK
Our Price: $599.95
Description: This is the complete 35 spline Extreme Duty axle package for the '07 and up Jeep JK Wrangler. Includes the forged alloy axle shafts, ABS tone rings, wheel studs, JK axle bearing retainer plates, Set 80 axle bearings, races, seals, and retaining collars. For this price these axles are supplied cut and splined to fit our RockJock JK rearend unit - or - custom cut and splined for those buying our housing ends and making their own housings. Available in 35 spline only. Sold as a kit.
Housing Ends
http://www.currieenterprises.com/CES...E.aspx?id=3119
Part #: CE-95011JK
Our Price: $129.95
Description: This is the new heavy duty housing end used on all Currie RockJock® JK rearends. Welds to the tube, accepts a set 80 wheel bearing, and is designed to allow the retention of the factory JK disc brakes. For use on the right or left side. Sold each.
Brackets
http://www.currieenterprises.com/ces...316&p=399.9500
Mfg: JK-BRKT-R
Our Price: $399.95
Description: This is the Currie heavy duty rear suspension bracket set for the '07 and up Jeep JK. Sold each.
that good for the rear what about the front kit is it going to be coming out
Old Feb 3, 2009 | 07:32 AM
brianb1222's Avatar
did that make your lights stay on?
Old Feb 3, 2009 | 04:57 PM
sliv3r's Avatar
i dont know if you guys have seen ti but there is a SB that the dealer is to program out the esp bas system on any rig running tires over 33's or heavy modded drive train jeep dealer here in anchorage said they would not do it even thou there was a SB about it but my local dodge dealer said they don't like it but sence the SB says to do it becuase it may end up in roll over if not shut off so they did it and i have no lights
Old Feb 3, 2009 | 06:39 PM
x No Compromise Offroad x's Avatar
do you have anymore info on the SB?...code #/reference #??....very interested
Old Feb 4, 2009 | 06:11 AM
sliv3r's Avatar
SB # 05-001-08
fidn it online and make sure to take it with you
