Show me your switch setup
Old Feb 27, 2016 | 02:24 PM
BFYTW's Avatar
Default Show me your switch setup
Not looking for SPODS. points awarded for creativity. Go!
Old Feb 29, 2016 | 07:58 AM
Vladimer's Avatar
Runs on a homemade fuse/relay box.
Ordered the new switch styles to re-do it but that was last year and haven't actually done it yet. Probably this spring/summer. But these are the new switches.
Old Feb 29, 2016 | 03:39 PM
Jonathan_JK's Avatar
Default Fiberglass Pannel
Here is my Fiber glass panel I made for my lockers. I actually built a better one because my wife said it was not perfect. So I broke down and laid a new set of glass down. The new one is hanging up the paint is drying.
But here is a picture of the old one.
The new one is way better and smoother all the way around top to bottom.
Wife's.... Keeping Husbands from slacking since 1000 BC
ID:	639157   Click image for larger version
Old Feb 29, 2016 | 04:48 PM
14JKWW's Avatar
So nothing fancy, but I ran some KC lights and didn't want to drill a hole. So I modified the supplied switch bracket and mounted it using the door strap retainer hook. Which conveniently allowed me to use the factory ground directly behind it.
Old Feb 29, 2016 | 05:06 PM
m4belisle's Avatar
nothing too crazy......wired up heated seats, and did some in-cab winch controls, in the daystar lower panel
https://im1.shutterfly.com/media/47a...D550/ry%3D400/
https://im1.shutterfly.com/media/47a...D720/ry%3D480/
Old Mar 1, 2016 | 04:11 AM
Default Day star lower panel
Will that panel work for the 2011+ interior? I'm going to probably do the winch switches and if I can figure it out a high idle switch for winching as well.
Old Mar 2, 2016 | 03:41 AM
14JKWW's Avatar
yes day star makes a lower panel for 2011 and up. But it has to be an automatic.
Old Mar 3, 2016 | 06:49 AM
BFYTW's Avatar
Hmmm. Thanks for the replies all.
Old Mar 6, 2016 | 07:34 PM
TweakJK's Avatar
Thank you! I am an aircraft electrician, so wiring my pump, lockers, lights, etc myself was the best part. These OTRATTW switches are nice. As someone who owns both the A pillar panel and the lower console panel, put your commonly used switches on the A pillar. It is much more intuitive to use.
Old Mar 7, 2016 | 05:36 AM
Default Lockout switch or toggle
Man that looks great!! I'm thinking about putting a lockout/safety for my locker switches just a simple push button or toggle. Probably just wire all the grounds to it and cut it off that way. So you have to toggle the button then activate the lockers. All I need is for my wife to hit the locker activate while going 55 down the highway when she hit it on accident to change the radio.
