Show me your switch setup
Old Mar 7, 2016 | 05:48 PM
TweakJK's Avatar
Originally Posted by Jonathan_JK
Man that looks great!! I'm thinking about putting a lockout/safety for my locker switches just a simple push button or toggle. Probably just wire all the grounds to it and cut it off that way. So you have to toggle the button then activate the lockers. All I need is for my wife to hit the locker activate while going 55 down the highway when she hit it on accident to change the radio.
Not a bad idea. My issue is that I trailer my jeep everywhere. When I load it on the trailer, I throw it in 4L, activate my lockers, and drive on with no ramps. Then I forget to turn off the pump and lockers and 2 days later I have a dead battery.
Old Mar 8, 2016 | 02:38 AM
Monte417's Avatar
Originally Posted by TweakJK
Thank you! I am an aircraft electrician, so wiring my pump, lockers, lights, etc myself was the best part. These OTRATTW switches are nice. As someone who owns both the A pillar panel and the lower console panel, put your commonly used switches on the A pillar. It is much more intuitive to use.
Where did you get those horizontal switches for the A pillar those things are pretty cool
Old Mar 8, 2016 | 09:25 AM
TweakJK's Avatar
OTRATTW.com
They can make you just about anything.
Old Mar 8, 2016 | 12:11 PM
Monte417's Avatar
OTRATTW.com They can make you just about anything.
Thanks
Old Mar 14, 2016 | 04:37 AM
BFYTW's Avatar
Thank you to everyone for responding on this thread. However. After searching all over online and looking at all of your setups, I decided I didn't want any of those. So here is the direction I went with my switches.
These are for my off road lights and rock lights. They are wired to a bank of switching relays under the hood for power.
There is a ton of room between the shifters and it's easy to access. I have room for more switches if I ever want to add more and they are easy to reach and discrete. Clean and simple.
Old Mar 15, 2016 | 01:51 PM
MotoJeeper's Avatar
Veteran: Marine Corp
It's not an sPod, it was cheaper, could do more, and has Bluetooth. Switch Pros 8100 mounted in a modified RR A pillar. I still need to call Switch Pros and get the vertical labels. The sway bar one isn't hooked up, and will probably become a switch for more lights.
Old Mar 15, 2016 | 01:56 PM
jlocker's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=640760"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=640761"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=640762"/>
Where did you buy that setup?
Old Mar 15, 2016 | 02:05 PM
MotoJeeper's Avatar
I got the panel from Northridge, and the Rugged Ridge A pillar from Morris 4x4. Then I cut a big hole in it. It's just big enough to fit the panel on the inside and hides the lines where the switch cut outs used to be.
Old Mar 15, 2016 | 02:06 PM
jlocker's Avatar
Nice I like it
Old Mar 16, 2016 | 03:06 PM
Jonathan_JK's Avatar
Attachment 640760
Attachment 640761
Attachment 640762
Looks great!!!! I actually like Switch-Pros over SPod setups anyways.
