show off ur leveling kit ( requesting pics and info)
#241
Originally Posted by 08BlackX
Here's my Tereflex leveling kit before tires. Still trying to decide what size to run on the stock wheels.
#243
Originally Posted by big c
Looks good any need for spacers
#244
Nope. They are the same height as the stockers and approx 3/4" wider. No issues at all with rubbing and they look flush to the fenders.
#246
18/59 springs, TF 1.5" leveling kit with single spacer in front, BW flat flares, wheel spacers, 35" retreads, stock Rubicon shocks, 1" extended bump stops.
I love the height, but I would prefer a softer ride. Shocks and extended brake lines are my next upgrade, I just need to carefully measure to maximize shock length. I may even alter shock mounts to be able to run longer travel shocks without increasing bump stops. After shocks and brake lines, I will figure out which coils I want to use to retain the same height as seen in picture but with the doors and hard top installed.
Suspension travel/flex is limited right now due to the stock shock length. I am OK with that until I get extended brake lines.
Rob
Rob
#249
Rob
Rob
I've installed the same except for leveling kit and just might do the one spacer in front as well.
