show off ur leveling kit ( requesting pics and info)
#354
You Betcha! Also, if you need any tools check out Harbor Freight. Got all the tools I needed under $50 and that included a 1/2" torgue wrench for $9.99 with cupin! I'm impressed with the torgue wrench and have used it several times to re-torgue including my spacers and wheel. I'll upload some pics when I can get my phone to co-operate with me. I would also loosen the bolts and/ or take off on axle mount on the trackbars while doing kit then set on level ground and re-torque to spec...i believe it was 125 ft lbs. Any problems chime in or let me know i'll give ya my number you can call if you have any questions.
#355
#356
Do most of you install the leveling kit yourself or do you have someone do it. I'm about to order one and have been reading up on installing it. It doesn't seem that hard with the right tools but I also don't want to mess something up since I've never messed with my suspension or rear breaks before.
Also, I'm pretty set on the teraflex leveling kit after reading all the positive talk about it. Is it worth it to also buy the steering stabilizer with it?
Thanks for your help!!
#359
Teraflex budget boost/leveling kit. 2" in the front, 1" in the rear.
Lift on, stock tires
35's on! (285-75-18, basically a 35-11.5. Mounted on the Jeep, they are just over 34" tall.)
#360
