silver w/ blue accents
Old 07-03-2015, 09:52 AM
bghunter2's Avatar
Default silver w/ blue accents
I have a silver 2dr and looking to start modifying it. So far did blackout grill, and plasti dip hinges, but was thinking about mmmmmaybe going with blue accents, such as seatcovers, hinges and maybe even the rims, but trying to find pictures.
Old 07-03-2015, 10:24 AM
zackjk's Avatar
When you plasti dipped your hinges did you leave the doors on? I did mine and taped newspaper around them and when I took the tape off it peeled up the plastidip around the edges of the hinges and turned out terrible.
Old 07-03-2015, 01:52 PM
whipple281's Avatar
You have to pull the tape off while it is still wet or you have to cut the edges with a razor blade before yo peal the tape off. I highly suggest to peel the tape off when the plasti dip is wet, it makes everything faster and easier then trying to cut around the edges and not to mess up the paint under it.
Old 07-03-2015, 01:55 PM
zackjk's Avatar
Thanks for the advice. I'll put another cote or 2 on later and try it out
Old 07-04-2015, 09:27 AM
bghunter2's Avatar
I did it with the hinges on and as advised take the tape off when wet. The great part is with plasti dip if it turns out bad just pull it off and do it again.
Quick Reply: silver w/ blue accents
