Trashed My Dana 44 Front Axle
Old May 12, 2009 | 10:11 AM
Offroadme's Avatar
ouch i would have been crying
Old May 12, 2009 | 10:18 AM
Little Fella's Avatar
So my big question is to what do you attribute the failure?
Tire size?
Use(Abuse)?
General wear and tear?
etc...
Could be a good indicator for those of us running similar setups as to when to start saving for that D60!!!
Old May 12, 2009 | 10:28 AM
wayoflife's Avatar
JK-Forum Founder
Tire size?
Use(Abuse)?
etc...
well, use/abuse is always a factor and we are hard on our jeep. however, i can honestly say that we only started to see breakage when we upgraded to our toyo 37x13.50's on walker evans beadlocks. these are really big/heavy tires - way more so than a set of BFG's and they have definitely been taking a toll on things. certainly, of the 3 tie rods that we've bent, 2 were bent forward and due to the torque of the tires on steep climbs. we've also gone through 2 steering boxes, 1 drag link, 1 locker and now this. when we were still running 35's, we never had any problems.
Old May 12, 2009 | 10:39 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
WOW thats crazy, I've seen broken axles, bearings and lockers but to see the tubes damaged like that is insane, now that is some serious trail carnage
You need teraflex to hook you up with one of those new Rubi elock plug and play 60's
Old May 12, 2009 | 10:41 AM
Piginajeep's Avatar
they only have rear 60's right?
Old May 12, 2009 | 10:43 AM
wayoflife's Avatar
JK-Forum Founder
what he said and while i would love to get a rear 60 too, i'm gonna have to focus my efforts into just a front for now.
Old May 12, 2009 | 11:29 AM
tkob1060's Avatar
well they are supposed to have the front 60's out or out soon, this from their thread
Originally Posted by TeraFlex
CRD60R's E-Lockers $3295.99 with 4:88/5:13/5:38 combinations. The axles are shipped with the gears/lockers/shafts installed. Yes a front axle will be offered/out in time for SEMA. TeraFlex has been make TJ front and rear 60's for years.
https://www.jk-forum.com/forums/show...t=60552&page=5
I think thats a pretty good deal being all together already, I just wonder how much that sucker weighs, someone said a dana 44 weighs 300lbs
Old May 12, 2009 | 11:35 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by G.I.JOE¤MFA¤
wow is the best way to discribe it. did you have any tell tale signs of a failure prior to it ripping apart??
seeing this im really worried about my build and how the D30 with chomolly axle shafts will hold up. think ill take it easy...lol if it does happen to me, it will give everyone something to talk about when they get home from the meet
1 thing i would change in my build would to have added the axles to the phase I build from the start. too late now
naw, no real tell tale signs. the boulders on this man made hill are like large loose bowling balls and they move around a lot. i typically stay off of this thing and should have this time around. catch one loose boulder wrong and it'll break something for sure.
for you, so long as you stick with 35's and are aware of your 30's limitations, you should be just fine with it. we've wheeled our TJ with 35's and on a 30 for a long time and never had any issues.
yeah, they are on the way but i can't wait till sema. currently, i am talking to dynatrac and it looks like that is what i will be going with - a new prorock 60.
Old May 12, 2009 | 11:40 AM
tkob1060's Avatar
Yeah I forgot they said by Sema till I read that again and Sema is definitely to far away
Old May 12, 2009 | 11:41 AM
Lo2aY's Avatar
Good choice on the front
I'm getting D60s for the same reasons! I don't want to blow up my factory axles
I think you can run an adapter for your wheels on the front..
