Unimog Axles Feasable?
hey all,
i'm at the point where my 3.21 gears are affecting my capabilities, and i'm ready for the next step.
I have a friend who has been aroun mogs his whole life, and his dad owns a unimog graveyard, seen in some 4x4 magazines.
I can get the parts for a good price if i wanted to. but is it feasable to run them on a daily driver, would the gearing be to high for the highway. i have no clue how to determine the wheel speed from the engine revs.
i have a 6spd.
thanks
i have a 6spd.
thanks
hey all,
i have a 6spd.
thanks
i have a 6spd.
thanks
Also bear in mind that the gear systems inside the end of the portal axles will build heat. The maximum sustained speed that those portal are rated for is around 55 mph - and that's with a +/- 40 inch tire on there.
I'd love to build a trail rig with 'mog axles - but it'll have to wait until I've got an appropriate tow rig.
I used to have mogs on my TJ (now it's 2 steering rockwells), and I loved it. Although, my TJ wasn't a d/d....... I was running a stock 4.0, 5spd, teralow, w/ 44" boggers. GPS would go about 65mph no prob........
If you are after an axle swap on your d/d I would go d60.....
My recomendation to you is, just regear your axles though. Cuz your talking about some drastic changes to your rig........ to from stock to mogs or 60's is a big deal.
And whom ever said that mogs can only run 20" wheels is way wrong....... I was running re-centered H1's (16.5" wheels).......
Pic of my TJ on mogs:
Sent from my ADR6300 using Tapatalk
Understood........ I have learned over the years, many if not most of the offroad shops dont know everything. It is wisest to do your own research via the web and actual offroaders (not shops). Cuz I have learned, that almost all shops are either biast to a product, or will try and veer you away from an idea you have just because they either dont carry the products to do it or are un-capable of doing such projects.
IE:
In my younger years, I went to a local OR shop called Mikes Off Road here in the DFW area. I was wanting a coil suspension on my CJ-5. The guy was very down on the idea and kept saying "if you want that, get a TJ" and " good luck getting a coil suspension on a CJ-5" I found a nother shop here in the DFW called No Limits.... I proposed the same idea to him and his reply was " when can you bring it in".
IE:
IE:
