Viair Install
#21
The line from the compressor to the manifold would need to be braided stainless. It gets hot to where you'd get burned touching it. I've got smaller compressors that hook directly to the battery and they get really warm where the air comes out as well after extended use. @Rednroll built a little system using the smaller compressors, he may be able to point you in the right direction on materials.
As far as shelf life on the hose- if it hasn't been torn up by the sun and isn't dried out then that'll work. I've got a smaller rigid line that leaves the manifold and goes to an external hookup at the front bumper, it doesn't see much light so it's in good shape.
