Wanted !!!! 33" tires with 3.5" or 4" lift
Old 08-29-2008, 02:06 PM
jeep_uae's Avatar
Default Wanted !!!! 33" tires with 3.5" or 4" lift
as in title, a picture of any jeep 33" tires with 3.5", 4" lift will do and if its possible of 2dr jk ... !!
Old 08-29-2008, 02:32 PM
Ryno's Avatar
4 inches of lift is way too much for 33s, especially when you can fit most 33s with no lift at all.
Here's a 2-door with 3-inch HD coils in the front and 3.25-inch coils in the rear...
33s, 3" lift, 3/4" spacer up front...
Same setup as above...
3.5" lift and 33s...
Old 08-29-2008, 03:13 PM
Ewok's Avatar
I would consider just going for 35's the really fill out the 2drs! But if 33's fit your fancy go for it!
Old 08-29-2008, 03:34 PM
Ryno's Avatar
35s are sort of the tipping point when modifying a JK on a budget. If you do any highway driving at high altitude it is practically a necessity to regear, which costs about $1100 to have done at a reputable shop. Plus 35s only provide an inch more clearance under the axles and diffs than 33s.
What I'm wondering is which has a greater effect on the seat-of-the-pants feel when you accelerate... Is it the added weight of larger tires that slows you down, or the torque-reducing larger diameter? I know it's a combination of both, but which slows you down more? Would a lightweight 35" tire bog down a Jeep the same as a heavy 33" tire?
Old 08-29-2008, 04:14 PM
BlackNorthernJK's Avatar
Ryno thanks for the pics, exactly what I was looking for too....
I honestly dig the look, I've been contemplating 33's or 35's ? ...as I'm about to FINALLY put in my 3" BD lift and regearing is a little too pricey for me right now...I think 3" with 33's looks pretty alright, and I should be able to manage with the stock gears
good post
Quick Reply: Wanted !!!! 33" tires with 3.5" or 4" lift
