Old Mar 3, 2011 | 10:19 PM
  #11761
Jeep Hound's Avatar
Originally Posted by NEWWRANGLEROLDCJ7
could you rock an O R fab roll cage with that thing, will that thing go in a 2011, thinking if so that's how I should roll as well
Id love to.. just dont have the money at the moment. I am not 100% sure if it will go with the 2011 because of the inerior change
Old Mar 4, 2011 | 03:05 AM
  #11762
GON WHLN's Avatar
Put on my 33" IROKs and went humming down the road, not too bad really.
PSC Brawler lite and superchips coming in today!!!
Old Mar 4, 2011 | 03:21 AM
  #11763
rinkishJK's Avatar
About to order the rest of my flex arms from Northridge!!
edit... ORDERED!!!!! thanks to the smokin deal i got at northridge.
thanks again david!!!!!!!!!
Old Mar 4, 2011 | 05:28 AM
  #11764
larzpdot's Avatar
Installed the FT 3" Premium SRS lift, wheels, tires, new shocks, and discos
Old Mar 4, 2011 | 05:55 AM
  #11765
TIE1ON's Avatar
Thumbs up Moved seat up and back
I am 6'3" (on a good day) and pushing 300lbs ... and little leg room or elbow room for me in my 07JKU.
So I pulled the drivers seat out, took off the brackets and drilled them back an inch, and reset the seat with 7/8" heavy washers ... 4 under each side of the front, 2 under the back.
There was no problem with folding down the back seat behind it, still room enough.
I had to do this to my full size Bronco, and need to replace the original bench seat in my 79 Ford 1 Ton ... odd enough, my wifes little MINI Cooper S has more leg and elbow room in it than any of my 4x4s.
Old Mar 4, 2011 | 06:58 AM
  #11766
4x4MTN's Avatar
Installed a Viair/Dominion OffRoad On Board Air System on the JK, works GREAT!!! Check out the Install Pic's..
Name:	On Board Air 8.jpg
Name:	On Board Air 6.jpg
Name:	On Board Air 5.jpg
Name:	On Board Air 2.jpg
Old Mar 4, 2011 | 07:31 AM
  #11767
08GreenRubi's Avatar
Just ordered my Teraflex 2.5" coil lift
Old Mar 4, 2011 | 07:46 AM
  #11768
IVAN BORRERO's Avatar
Switched from hard top to soft top. Spring fever, you already know.
ID:	133523   Click image for larger version
Old Mar 4, 2011 | 07:52 AM
  #11769
Nice, I am going to swap mine this weekend
Old Mar 4, 2011 | 08:33 AM
  #11770
medic_23387's Avatar
Painted my hard top flat black.
Before
After
