Old Mar 20, 2011 | 02:20 PM
  #12101
Rockroaster's Avatar
Cleaned 'er up real nice...
Old Mar 20, 2011 | 02:42 PM
  #12102
gtin's Avatar
Finally got the carpet out of mine. Amazing how much that helped the words allergies from the mold and mildew in the carpet from the wonderful leaks that the jeep has
Old Mar 20, 2011 | 03:10 PM
  #12103
Jae Suite's Avatar
Finally installed the CB
Old Mar 20, 2011 | 04:51 PM
  #12104
D1EHARD's Avatar
Installed OR-Fab Tire Carrier/Jerry Can Rack.
Old Mar 20, 2011 | 05:17 PM
  #12105
Cedo Nulli's Avatar
Top down, doors off, new Body Armor trail doors on, replaced my existing Gobi lightbar with the Recon version, Safari Straps Warrior Cage on, Superwinch cover on...life is freakin good.
Old Mar 20, 2011 | 06:03 PM
  #12106
meljr's Avatar
Default AEV Hood, Snorkle and Powertank mounted
Mounted Powertank to fabed bracket on my OR-FAB rear tire/can carrier:
Installed AEV heat reduction hood and snorkel
ID:	140135   Click image for larger version
Old Mar 20, 2011 | 06:20 PM
  #12107
DjHeath84's Avatar
Default Coil Springs :)
Custom modded my breather tubes and also added some Rubi Unlimited coils to my sport jk. Before and after pics attached
ID:	140158   Click image for larger version
ID:	140159   Click image for larger version
ID:	140160   Click image for larger version
ID:	140161   Click image for larger version
Old Mar 20, 2011 | 06:35 PM
  #12108
pickardjm's Avatar
Finally finished my Rough Country 3.5 lift. I screwed up my drag link end when I replaced the pitman arm and had to get a new one today. Now I need some tires. Anyone giving away 35s on 18s in Socal?
ID:	140163   Click image for larger version
Old Mar 20, 2011 | 06:36 PM
  #12109
SAR JK's Avatar
Default Nice Trailer
Originally Posted by northingtonequipmentinc@y
Finished the rough assembly of my JKs trailer. Finished the multi-axis hitch, plumbed the propane to the outside, built the propane tree, built the shelf and attaching hardware for it, wired the trailer with LED lighting. Should be complete by forest fest!
Your trailer looks good. I was kind of thinking about building an off road trailer like yours. Did you start from scratch and build from the axle up or did you start with a standard box?
The Adventure Trailers look nice but are expensive.
Old Mar 20, 2011 | 06:42 PM
  #12110
BurnDoubt's Avatar
Poison spyder light!! On n off!!
ID:	140167   Click image for larger version
