Old May 22, 2011 | 09:21 AM
  #13401
Colemanation's Avatar
Default Beginning Mods
Simple add-on's while I contemplate bigger projects. "Oh Shit" handle and hook for dry-cleaning!
First time posting pics....if the images above don't work..this is an EPIC FAIL.
Old May 22, 2011 | 09:25 AM
  #13402
Battlefrog's Avatar
Originally Posted by JKRVEE
Got my trailer back from paint, Monday it goes to Line-X, then I can finish it!
Did u fabricate this yourself or was it a previous owners build... That is damn cool.......
Old May 22, 2011 | 09:26 AM
  #13403
scooterferret's Avatar
Default hard top removal/superchip
This week I purchased a superchip flashpaq and I'm having some problems with the website. I also removed the hardtop by myself and I dont recommend that. Its pretty heavy and awkward.
Old May 22, 2011 | 09:33 AM
  #13404
Battlefrog's Avatar
I use to remove and put the camper shell back on my dodge by myself... I understand your pain....
Old May 22, 2011 | 09:39 AM
  #13405
JKRVEE's Avatar
I bought it as an axle and a box, thanks!
Old May 22, 2011 | 09:42 AM
  #13406
Battlefrog's Avatar
What did the kit cost you, and where did you purchase it from... Thanx
Old May 22, 2011 | 10:23 AM
  #13407
JKRVEE's Avatar
I bought it from a guy as basically a rolling box. When it's finished, it will have 200watt music with Sirius radio, built in propane system, 10 gallon water tank with an rv style pump, 12v battery, 1000 watt inverter, solar panel, all LED lighting inside and out, a removable cooking shelf, and of coarse......coors light on tap!
Old May 22, 2011 | 11:08 AM
  #13408
f8259o8's Avatar
Default Trailer 7 point hook up
Name:	trailer plug mod.jpg
ID:	163104This week i moded my stock bumper by moveing my trailer plug in to the bumper.
1. 21/8 hole saw to cut thru plastic and some of the metal cross member ( I only cut 1/2 inch in and 1/2 down give or take.
2. Remove plastic bumper remove plastic test fit plug.
3. Hammer the cut peice down . do test fit with bumper and plug.
4. Run connection wire over cross member . Install bumper with out plug. Pull wire thru hole.
5. Conect plug and wire connection. Screw in done.
Why did i do this mod simple it has been ripped off 3 times and i have strated my trailer build .Click image for larger version
Old May 22, 2011 | 11:13 AM
  #13409
Battlefrog's Avatar
Originally Posted by jkrvee
i bought it from a guy as basically a rolling box. When it's finished, it will have 200watt music with sirius radio, built in propane system, 10 gallon water tank with an rv style pump, 12v battery, 1000 watt inverter, solar panel, all led lighting inside and out, a removable cooking shelf, and of coarse......coors light on tap!
holy crap.....
Old May 22, 2011 | 11:20 AM
  #13410
Sapper12b's Avatar
While at the Houston Jeep Fest I picked up the Rugged Ridge arm rest ... man that arm rest is an awesome thing to have.
