Old Jun 18, 2008 | 04:42 AM
  #1741
deconstructionist's Avatar
Originally Posted by neoxxis
Do you have pics of the Antenna thing?
I'd like to push it back so it fits along the windshield but I could not turn the support...
I do see 2 screws inside the body panel but there is no access there for tools...
Thanks!
No pics- I can snap some later today....but easy enough mod. Remove Antenna, Gently remove plastic cover, unbolt the 3 bolts holding the antenna plate down. (IIRC its 7mm bolt heads).... there is a small tab near the 12 O' clock position on the bracket that sits in a notch on the body: I used a rough file to extend/enlarge that notch- then finished with a fine file so the bracket could be rotated back to about the 11 O' clock position. Hold bracket back in place to use as template for new bolt holes (I just opted to use self taping sheet metal screws). Remount bracket, reinstall plastic cover & then re install the antenna.
Old Jun 18, 2008 | 06:29 AM
  #1742
TommyG's Avatar
Originally Posted by Zak
Where did you get the light switch in between the hazard and esp switch on the factory switch panel? If anyone knows where I could pick that up, please let me know. Thanks.
Old Jun 18, 2008 | 07:09 AM
  #1743
HappyCurmudgeon's Avatar
Eternal ***erator
That is the automatic headlight leveling thingamajig on export Jeeps. The domestic ones have the passenger airbag deactivation light in it's place.
Old Jun 18, 2008 | 08:41 AM
  #1744
JoJo's Avatar
Default Gotta Love Utah
Got her feet wet.....In the river and snow.
Old Jun 18, 2008 | 11:56 AM
  #1745
JulietKilo's Avatar
I dont have a deactivation light in the place, its just a blank panel. In fact I have no way of knowing when my passenger airbag is deactivated. But I would like to have a switch available for that spot next to my locker switch.
Old Jun 18, 2008 | 03:22 PM
  #1746
myklt8's Avatar
OK
just put on the RRC headlight, turn signal, and side marker guards. (I put the tailight ones on last night)
Old Jun 18, 2008 | 03:53 PM
  #1747
TommyG's Avatar
+1 on that!!! Is there any way we could buy the switch and intall it in the cluster? That would be a great spot for the toggle for when I get the KC driving lights.
Old Jun 18, 2008 | 04:23 PM
  #1748
Piginajeep's Avatar
Installed a front 44 lastweek!
Old Jun 18, 2008 | 04:31 PM
  #1749
Thanks man!
I did not think that the plastic cap was removable...
I guess I'll have to drill holes then...
10-4.
It snaps on/off...it was a bugger to get off....need a real thin pry stick, scrwdriver (WATCH THE PAINT!!!!!) and I worked around the circle until it just plopped right off.
Old Jun 18, 2008 | 05:42 PM
  #1750
PainKiller's Avatar
Originally Posted by SoCalChuckster
Finally got my KC lights mounted and all wired up. I mounted a set of 8" KC driving lights to my LOD front bumper using a modified bracket, and a set of 8" KC long range lights to a set of Mopar windshield brackets. I also finally got the gas can/cooler racks installed onto my LOD rear signature bumper/tire carrier.
Chuck
What did you do with the antenna ? I can't see it in any of the pics.....
