Old Mar 3, 2012 | 11:59 AM
  #19741
rinkishJK's Avatar
Originally Posted by fadeout
Got um mounted up now waiting for nightfall.
Looks sweet man! I might want to see these in person before I buy them.
Old Mar 3, 2012 | 01:57 PM
  #19742
BrowniesJK's Avatar
You have been busy...
Old Mar 3, 2012 | 01:58 PM
  #19743
NoDiRTnoGloRy's Avatar
I had my 285/70/17 duratrac tires installed today and did an oil change with mobil 1 synthetic
Old Mar 3, 2012 | 02:41 PM
  #19744
Jk4d2008's Avatar
bedlined hinges and did the grill mod
ID:	284546   Click image for larger version
ID:	284547   Click image for larger version
Old Mar 3, 2012 | 04:16 PM
  #19745
relayer4u's Avatar
Moved the evap can and factory skid on my 2012 over by about 2 inches:
Old Mar 3, 2012 | 04:23 PM
  #19746
bbolander's Avatar
that looks like a great solution. looks like you didn't disconnect the cannister - how did you drill the new holes in place?
Old Mar 3, 2012 | 04:26 PM
  #19747
theplasterman's Avatar
Put the rugged ridge stubby and warn winch on.
Old Mar 3, 2012 | 04:31 PM
  #19748
jfleur91's Avatar
Dammnnn man nice
Old Mar 3, 2012 | 04:51 PM
  #19749
relayer4u's Avatar
It was real easy.
Measured the distance between the two front bolts at 1 7/8 and marked a new spot front and back for the new holes.
Removed the two front bolts and drilled a pilot where marked and then opened the new hole up with a step bit, shot some primer and waited, then shot some Rustoleum gloss and waited again. Removed the rear bolt and moved everything towards the exhaust so I could instal one of the bolts in the original inside hole on the front to the original outside front threaded hole.
Then did the drilling and painting waiting and painting on the rear side, waited for paint to firm up and bolted everything back tight.
Let stuff hang, pull down for the pilot drilling and watch out for arm burns with the step bit!
Old Mar 3, 2012 | 04:57 PM
  #19750
Cherryred's Avatar
Teraflex Leveling kit
