Old Mar 12, 2012 | 03:19 PM
  #19991
MotiCross's Avatar
Order and installing this weekend:
Rigid dually's
Pioson spyder EVAP plate
Adjustable rear sway links
Daystar dash
Daystar switch panel
Rugged ridge mirror sleaves
Oh this is going to be fun
Old Mar 12, 2012 | 03:31 PM
  #19992
RUBI-VET's Avatar
Originally Posted by Bubbacon
Washed her, let her bask in the sun, cleaned out her garage spot, touched up the scrapes on her rock rails, and ordered her a procal so her speedo and traction control behave... Oh yeah, and filled her up with 93 (again). :-)
93 ouch!!!!!
Why 93 may I ask? No need unless you have a supercharger or turbo kit
Old Mar 12, 2012 | 04:12 PM
  #19993
Bubbacon's Avatar
Originally Posted by RUBI-VET
93 ouch!!!!!
I always run 93. Better performance.
Old Mar 12, 2012 | 04:19 PM
  #19994
scemracing's Avatar
Higher octane fuel burns slower which causes you to lose power. High performance engines would make more power on lower octane fuel but they can't because of detonation issues. They only use it cause they can produce more power by using it.
Old Mar 12, 2012 | 04:56 PM
  #19995
Bubbacon's Avatar
Uh, no. Increasing the compression ratio ( aka higher octane ) ... Produces more power... For a given displacement.
Old Mar 12, 2012 | 04:58 PM
  #19996
krazyjoker711's Avatar
Originally Posted by JK-421
Installed the Teraflex 2.5" Coil lift with Bilstein shocks, 1" Spacer up front, 1/2" spacer in the back and 1.5" Wheel spacers in preparation to pick up some 315/75/16 Duratracks and Cragar Soft 8's this Thursday
The ride quality is excellent. More plush than stock, although the high-speed handling leaves a little to be desired. It's a bit flighty on the freeway, but still perfectly driveable. I will be getting some adjustable LCAs eventually to correct the issue.
The Kit:
Attachment 288090
Before:
Attachment 288091
After:
Attachment 288092
Attachment 288093
Edit: Also added a sticker
Attachment 288110
nice looking jeep!!
Old Mar 12, 2012 | 05:08 PM
  #19997
scemracing's Avatar
I don't know what your smoking but higher octane fuel does not increase your compression ratio! It allows you to run a higher compression ratio if you were say building a engine! You can not increase the compression ratio of your engine unless you take it apart and machine the heads or install custom pistons.
Higher octane= slower burn= less boom=more controlled burn
Lower octane = faster burn = more boom=less controlled burn
Old Mar 12, 2012 | 05:15 PM
  #19998
CATCHONE's Avatar
Default My Version of the Under Floor Storage
Added a Storage Cabinet to the back
Here's the write up
https://www.jk-forum.com/forums/show...00#post2899500
Name:	final fit 4.jpg
ID:	288316   Click image for larger version
Name:	Final fit 3.jpg
ID:	288317   Click image for larger version
Name:	Final fit 2.jpg
ID:	288318   Click image for larger version
Name:	Final fit 1.jpg
  #19999
Drop Top's Avatar
Originally Posted by jeepfanatic
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=286742"/>
Added lift and tires
Could you post some more pics?? Looks sick
Old Mar 12, 2012 | 06:09 PM
  #20000
1978cj7jk2012's Avatar
Originally Posted by evilgenius
lookin' good!
Thank you! That really means alot! This one is almost done untill the warranty is gone. Meantime i need to finish my cj7. Hard to do though when 16 and broke lol. But i love my jeeps. And a hi-po almost broke his neck today trying to decide whether or not to pull me over! I got lucky this time. I guess I'll see how far it goes. The jeep is cursed. Ticket the 12th day and rearended the 8th..... Whats next?
