Old 05-30-2012, 05:57 PM
  #22381
RockChalk-JK's Avatar
Installed a TF 2.5" coil lift, steering stabilizer, 315/70R17 Duratracs, and Moto Metal chrome wheels.
Old 05-30-2012, 10:18 PM
  #22382
Namtaru's Avatar
I haven't posted in this thread yet, so I'll post everything I've done in the past month..........
Cleaned out the throttle body
Dirty
Clean
Also cleaned the air filter, she should be breathing a bit better now
Set up my custom "do it yourself" hard top lift....
Fixed the broken e-brake, the flat spring came off the ridge it was grabbing on to and the cable itself even came out of the track, fixed that all up...
Broken
Fixed
A couple weeks ago I installed the new KC lights, and also brand new stock Rubicon shocks from a fellow Jeeper
Bought some gutter guards from home depot, and after some cutting with the snips I painted them black and mounted them behind the grille
Before
First install
Paint
Setup
Final
And finally.... did the front bumper today
Before
During
After
Old 05-31-2012, 02:59 AM
  #22383
kaptkrappy's Avatar
She looks like shes smiling.
Lots of good work there.
Old 05-31-2012, 03:54 AM
  #22384
Tootie's Avatar
Changed out the Freedom Top to the Trektop NX
Old 05-31-2012, 04:02 AM
  #22385
DCR-Jk's Avatar
Installed 4" lift kit and new 35" wheels and tires
Changed the front rear bumpers
Side steps
Front and rear drive shafts
Xrc 10 winch
Thinking about changing the sway bar the steering is a bit tilted also I need more power these wheels are heavy
Any suggestions?
Old 05-31-2012, 04:14 AM
  #22386
aldaman's Avatar
Side steps
Xrc 10 winch
Attachment 323833
Any suggestions?
Looks good. Did you use a Procal to calibrate your speedometer? If you have an auto trans that will help with the shift points and give you back some power. You can start off with an aftermarket exhaust like Dynomax, Magnaflow or Flowmaster. Other than that a programmer will help with some extra ponies, but the aftermarket companies haven't found a way to crack the computer....Lastly would be regearing to 4.56 or 4.88...
Old 05-31-2012, 06:46 AM
  #22387
dpowell5523's Avatar
Originally Posted by John_Mora
I have COAST 1310, aftermarket drive shaft. You need to grease the niple neer the front U-Joint
Nope I still h e the factory stick under there. Can't replace it till the warranty goes out in two more years.
Old 05-31-2012, 09:58 AM
  #22388
Bubblegoose1's Avatar
Originally Posted by jayerouth
Added a new hitch accessory.....
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=323665"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=323666"/>
I like it; just needs 3.5" lift and 35s.
Old 05-31-2012, 12:17 PM
  #22389
DCR-Jk's Avatar
Thanks for the input
I didn't use the procal cuz mine has a manual tranny. And I'm using the gps on my phone to know the speed difference.
Hopefully I'll save some cash and install a good exhaust system.
Old 05-31-2012, 04:14 PM
  #22390
GreenJK07's Avatar
Nothing today but got my tranny cooler in to be installed this weekend .
