Originally Posted by mattgt5
Installed crown extended brake lines, arb diff covers and nitro sleeves
Originally Posted by Bubbacon
I'm diggin this...
Originally Posted by Rule18
I took the Rustoleum Truck bed liner route.
1. Removed grille and then signal lenses.
2. Roughed up grille a little with 180 grit
3. Applied one coat of Rustoleum Plastic Surface Primer (let dry one hour)
4. Applied three coats of bedliner (let dry two hours between coats)
5. Put it all back together
Originally Posted by jeepasaur
How the rustoleum holding up? I have mixed feelings about duplicolor
Originally Posted by 1978cj7jk2012
Sprayed a nice little strip of flat black bed liner down the side for covering/preventing paint chips. (zolatone, same stuff as my grill)
Originally Posted by inspect-a-home
Finally! after being soaked at least a couple times I removed the carpet on my 4 door JK.
Did the same to my '11 rubi 2dr... Got caught in the massive storm that ran through Indiana, then Ohio, Wva, and va... Have been running topless and odorless for weeks . During the storm I had over 1.5" of water in my floorboards. Pulled all the carpets, drain plugs, dried it all out and put the carpets back in. Left all the plugs out. Top and doors still off :-)
