Old Jul 1, 2012 | 08:09 AM
  #23191
Beau's Avatar
Originally Posted by Bubbacon
I'm diggin this...
X2...that looks good
Old Jul 1, 2012 | 08:20 AM
  #23192
GreenJK07's Avatar
Originally Posted by mattgt5
Installed crown extended brake lines, arb diff covers and nitro sleeves
How was the nitro sleeve install? I'm about to order some for my front 30.
  #23193
1978cj7jk2012's Avatar
I'm diggin this...
Thanks. Took me about 4 hours, that's taking all the flares off, taping, prepping, spraying, and putting flares back on.
Old Jul 1, 2012 | 10:43 AM
  #23194
jeepasaur's Avatar
Originally Posted by Rule18
I took the Rustoleum Truck bed liner route.
1. Removed grille and then signal lenses.
2. Roughed up grille a little with 180 grit
3. Applied one coat of Rustoleum Plastic Surface Primer (let dry one hour)
4. Applied three coats of bedliner (let dry two hours between coats)
5. Put it all back together
How the rustoleum holding up? I have mixed feelings about duplicolor
Old Jul 1, 2012 | 10:51 AM
  #23195
GreenJK07's Avatar
I have used duplicolor bed liner on my rims, entire tub, fender wells and door hinges and the stuff is solid. It hasn't faded or cracked/peeled either. I would recommend it everyone. I don't use the one with Kevlar in it though. I can't speak for that brand of the liner.
Old Jul 1, 2012 | 12:14 PM
  #23196
HannibleMP's Avatar
Originally Posted by 1978cj7jk2012
Sprayed a nice little strip of flat black bed liner down the side for covering/preventing paint chips. (zolatone, same stuff as my grill)
Looks awesome man
Old Jul 1, 2012 | 12:17 PM
  #23197
inspect-a-home's Avatar
Finally! after being soaked at least a couple times I removed the carpet on my 4 door JK.
Old Jul 1, 2012 | 01:04 PM
  #23198
Bubbacon's Avatar
Did the same to my '11 rubi 2dr... Got caught in the massive storm that ran through Indiana, then Ohio, Wva, and va... Have been running topless and odorless for weeks . During the storm I had over 1.5" of water in my floorboards. Pulled all the carpets, drain plugs, dried it all out and put the carpets back in. Left all the plugs out. Top and doors still off :-)
Old Jul 1, 2012 | 01:06 PM
  #23199
Bubbacon's Avatar
That's doorless, not odorless... Too funny. Stupid spell check on the iPad!
Old Jul 1, 2012 | 01:19 PM
  #23200
fadetogray's Avatar
Got my stubby antenna installed, repainted the gas cans on my tire carrier black, and got my Xenon flats installed.
ID:	336030 Click image for larger version
ID:	336031 Click image for larger version
ID:	336032 Click image for larger version
