#2613
GOT THIS INSTALLED
CHECK OUT THE BUILD THREAD
https://www.jk-forum.com/forums/jk-show-tell-33/official-jk-buggy-carolina-truggies-build-thread-8-4-08-a-53661/
#2614
Today I took the steering linkage out, pulled the back and greased i t, the spline were absolutely dry from the factory. I changed the antenna to a stubby rubber one; had to drill the center of a bolt that fit the enormous Jeep post threads, cut the bolt and welded the provided GM stem into the bolt. I also changed the oil and filter.
#2615
for the guys asking about the iphone/ipod/cb mount.........its custom made by BULLFROG(TOADS husband i believe) just pm her if you're interested and it'll be to your doorstep in a few weeks....i love mine!!!! and a great price too cause you cant buy that kind of thing anywhere....believe me i looked
#2617
yep what he said ^^^^^ pm Toad and she will have one made and shipped to you.
As for the cable, I got it at Best Buy. Its "not" an iPhone plug, but one for an iPod. They all work the same.
#2618
Its been a busy week for me, and Phase 1 of my build is almost done!
2.5" TF Coil lift, 1.5" wheel spacers, and KC slimlights....just waiting on my bumper which will be next week hopefully!
Before:
After:
Before:
After:
#2619
I installed AEV corner guards and Mopar tail lamp guards
The AEV corner guards were purchased from David at Northridge 4x4 and arrived the next day.
While the box did not contain instructions, I was able to print a copy (10 pages with pretty good
color pictures) off the AEV website. Because the driver's side seemed to fit better than the
passenger side and I did not have anyone to help hold things in place, I decided to do the driver's
side first. The gas filler also helped me position the driver's side guard and I used blue painters
tape to tack everything in position before marking and center punching the 17 or so 25/64" holes
that had to be drilled in the body for the nutserts.
While it was harder to position the passenger side without help and I got it a smidgen too low
where it almost rubs the tailgate hinges, this side went a little smoother than the first and I was
able to tighten the bolts in such a way that the guard ended up conforming quite nicely to the
body when I was done.
The Mopar tail light guards went on last and were practically no-brainers compared to the AEV
corner guards. I say practically because I installed the first one upside down on the wrong side
I would have liked to have installed my Mopar Fuel Door, but I could not remove the original part
that clips to the inside of the body by releasing the retaining clips from the tail light housing, so that still remains to be done.
Oh yes, I also kind of installed a fire extinguisher by using 3 zip ties to fasten it's holder to the
rear driver's side of the roll cage.
