Old Feb 15, 2013 | 09:22 PM
  #29111
Sharkbait98's Avatar
I installed my procal today, it was super easy and lowered the tpms to loke 24psi so if it goes off i know i have a problem.another added bonus is now i know how fast im going...yay
Old Feb 15, 2013 | 09:34 PM
  #29112
wishithadahemi's Avatar
Replaced stock breather front and rear left factory trans alone just fine I bought 14' of 5/16 fuel line hose and couple hose clamps came to total of $27 .
Took front breather hose and is tied to other wire loom I got for my duallys I got it zip tied in 4 spots along the way I left a lot of slack for my 2.5" rk max travel im saving for atm and will trim if needed.
The rear I took off my back tire and drilled into the plastic cover under light area new to 2012 I think before was open before.
Used a 3/4 bit to drill out hole perfect size for the 5/16 hose since was almost 3/4" diamater. Then used breathable foam spray not expanding the foam filled the factory foam wich I had drilled threw perfectly.I also drilled two small holes behind hinge bracket about 1" apart then used zip tie to secure breather hose.oh forgot sprayed holes drilled with rustolium spray bomb so rust wouldnt start on new expossed metal.
I used all factory hose brackets also just bent front bracket that had the factory zip tie so would not rub hose...
Oh for the breather cap to install in new hose I just heated hose up with a lighter for a few secs and cap just slid in and when cooled air tight..
ID:	422776   Click image for larger version
Old Feb 15, 2013 | 10:29 PM
  #29113
Killtrout's Avatar
Kept it dry.
Old Feb 15, 2013 | 11:11 PM
  #29114
stevenJK13's Avatar
Originally Posted by marshman1987
Looks good man. What lift and tires are you running?
I got the TF 2.5" coil lift with bilstein 5100's. the tires are 305/70/17 km2's. rides like a dream now.
Old Feb 16, 2013 | 01:21 AM
  #29115
Omani2010's Avatar
Put the hard top back on and gave her a wash
Old Feb 16, 2013 | 06:11 AM
  #29116
bluebear's Avatar
Originally Posted by Tripletsi
Could I get a picture from the rear of the Jeep with the door closed? I've got a black JKU and debating on powder coating my TF hinge gloss black to match the body or just leaving it as is...
Here you go
Old Feb 16, 2013 | 06:29 AM
  #29117
Blkhwk976's Avatar
Replaced OEM backup lights with LED lights, what a difference!!!!! Show here next to a buddies with the stock lights
Old Feb 16, 2013 | 06:40 AM
  #29118
web architect's Avatar
Nice. What lights/kit did you use?
Attachment 422847
Old Feb 16, 2013 | 06:53 AM
  #29119
JK-Willy's Avatar
First of all I'm new to the site and would like to say this is the best site I've found for info and mods for me to do to my 2012 rubi, thank you
Hester day I installed my 5" Piaa lights on the windshield and also while I was doing the wiring for the piaa's I decided to do the front signal/ marker mod I read about on here and it worked AWSOME!
Old Feb 16, 2013 | 07:11 AM
  #29120
Tuffy
