Old Mar 23, 2013 | 03:46 PM
  #30291
JerryOnly's Avatar
What was used for the mounts? I have everything except the mounts.
Old Mar 23, 2013 | 03:54 PM
  #30292
JerryOnly's Avatar
Originally Posted by BrightSilverRubicon
I did the grill mod. I used 10 gauge expanded metal from Ace Hardware. I think for the 24"x24" metal, spray paint, mounts, and zip ties. I'm in for about $43.
What mounts did you use
Old Mar 23, 2013 | 05:03 PM
  #30293
TJM12's Avatar
Rear upper and lower adjustable control arms. It moved my axle back about 1 1/4 inches. Now it centers up in the wheel well again. Not to mention they are much beefier and more flexible than stock.
Old Mar 23, 2013 | 05:22 PM
  #30294
ballsdeep's Avatar
New shocks.
Old Mar 23, 2013 | 05:38 PM
  #30295
Slupe's Avatar
Coast 1310 Front Driveshaft to get the flex out of the RK XFactor. Teraflex tire carrier for 35s.
Old Mar 23, 2013 | 05:41 PM
  #30296
Rob309's Avatar
Originally Posted by Billbikes
Much less than everybody else has done, but having my 33" Nittos installed. Putting the Teraflex leveling kit on tomorrow.
Nice wheels, got the same ones.
Old Mar 23, 2013 | 05:46 PM
  #30297
NTXRUBICON's Avatar
Well I finished the steering!
I was able to get my guys at Maximum Elevation in Paris TX to help me out with this one!
Thanks Collin, Jay & James!!!
If you ever need any help and you are in NTX go see Maximum Elevation or if your in Moab This week they are there as well.
// Maximum Elevation
Due to the Drag link being a RE Link and not stock we had to do a flip from the under mount to over mount on the knuckle that gave the arm plenty of room to be able to mount the passenger side portion of the RC dual steering stabilizer as you can see in picture 1
Then we changed side on the outer mounting tabs on the stabilizer kit and that pushed the shocks out just enough to give us plenty of room for the track bar. Which means no more caved in stabilizer shocks "that's a good thing!"
ID:	437424Click image for larger version
ID:	437425Click image for larger version
ID:	437426Click image for larger version
NTX RUBICON
Old Mar 23, 2013 | 06:31 PM
  #30298
lobster86's Avatar
They sell 1x1" mounts made for zip ties, they are in the electrical dept in any home improvement store. These are what I used. Just male sure it's warm enough for them to stick.
ID:	437437   Click image for larger version
ID:	437438   Click image for larger version
Old Mar 23, 2013 | 06:48 PM
  #30299
ZMagic97's Avatar
Installed the OR-Fab can carrier. I still need to shave the passenger tail light guard in the morning but that's all that's left. Very impressed with this thing so far.
Old Mar 23, 2013 | 08:21 PM
  #30300
BrightSilverRubicon's Avatar
Yep, this is what I used. I found it a lot easier to use 4" zip ties and feed them through the mounts that u put on the back of the Jeep grill. After you feed them through, you can lay the metal grill over them and use needle nosed pliers to grab the zip ties. There are probably a million ways to do it, but this was pretty easy for me.
