Old Apr 7, 2013 | 12:21 PM
  #30801
SHUGAN's Avatar
Originally Posted by BigRedJK
That's great! I'm going to install the flush mount in my LoD rear soon as I find a pair at reasonable price. Any issues with the install? What'd you use to cut the bumper?
Angle grinder and sawzall. Only issue I ran into was the template rigid provides is an eight of an inch too small on the bottom so you have to cut the whole a little bigger
Old Apr 7, 2013 | 12:33 PM
  #30802
mudr's Avatar
Originally Posted by k0260
I have the same Rugged Ridge grill, and yeah I agree the initial fit is pretty funky.
The ruggid ridge aluminum front and rear bumpers were a pain also and again the bolt didn't line right up so had to improvise!
Old Apr 7, 2013 | 12:34 PM
  #30803
mudr's Avatar
Originally Posted by SHUGAN
Installed my flush mounted rigid dually led light into my smittybilt XRC rear bumper. Also installed my OTRATTW switches and switch panel flush mounted in front of the cup holders and behind the stick.
That's pretty cool set up!
Old Apr 7, 2013 | 01:45 PM
  #30804
EdsJunk's Avatar
Hood Louver.... This part sucked!
Old Apr 7, 2013 | 02:35 PM
  #30805
GreenJK07's Avatar
I'm digging this!! I really need a reverse light!
Old Apr 7, 2013 | 02:43 PM
  #30806
GreenJK07's Avatar
Worked a solid 14 hours this weekend on the rig. Installed Adam's front and rear driveshafts, custom made some bump stops front and rear (front out of aluminum and rear out of steel) and installed some rock krawler rear correction wedges. Ride is so much smoother with straight rear coils on my RK lift. And finally some home made rear lower coil retainers (hose clamps) to match my front and rear Teraflex coil retainers.
ID:	444090   Click image for larger version
ID:	444091   Click image for larger version
ID:	444092   Click image for larger version
ID:	444093   Click image for larger version
ID:	444095   Click image for larger version
Old Apr 7, 2013 | 03:13 PM
  #30807
bbreen24's Avatar
Installed an MBRP exhaust and Poison Spyder front bumper
Old Apr 7, 2013 | 03:15 PM
  #30808
marshman1987's Avatar
Took the doors off for the first time this year :thumbs up:
Old Apr 7, 2013 | 03:37 PM
  #30809
Jersey_Devil's Avatar
Installed and wired my 50"er!Click image for larger version
ID:	444125Click image for larger version
ID:	444126Click image for larger version
Sent from my Samsung Galaxy Tab 10.1 using Tapatalk 2
Old Apr 7, 2013 | 03:40 PM
  #30810
echoshotz's Avatar
I thought that was the best part! It got fun after I got over the whole cutting into a perfectly good hood thing
