Old Oct 30, 2008 | 06:46 AM
  #3101
HappyCurmudgeon's Avatar
Eternal ***erator
Originally Posted by Klietable
Thanks,
So to clairify, no problem running as is now. (followed write up and used ratchet strap to reconect to factory bracket). But if I use the extension bracket, the axle will be recentered.
Yes, the bracket would help to get it recentered, wether or not it would be exact is anyone's guess as the brackets have a fixed length.
what type of bracket are you talking about? axle end or frame end of the trackbar? If it's the frame end one, i would install it. the axle end one, depending on what you have, i would be leary of.
Old Oct 30, 2008 | 07:09 AM
  #3102
Klietable's Avatar
Thanks,
I'll check it out and see which it is. I really didn't even look at it. It is the one that came with the kit, but since I was following the write up, it didn't come into play.
Old Oct 30, 2008 | 07:24 AM
  #3103
Eternal ***erator
This one? this is Tera's frame end bracket. I wouldnt hesitate to use this.
Old Oct 30, 2008 | 07:51 AM
  #3104
ledcubbie's Avatar
FINALY... got my Teraflex BB installed and also put on the Best Top High Rock Slider Steps.
I followed WOL's write up on the BB and didn't use the Track Bar relocation bracket. What would be an advantage/DisAdvantage to not using it?
How long did it take you to install? I'm planning on doing mine this weekend.
Old Oct 30, 2008 | 07:58 AM
  #3105
JKGoose's Avatar
Installed my Full Traction 3" lift.
Before:
After:
Old Oct 30, 2008 | 09:48 AM
  #3106
pstone24's Avatar
Default Finally my own stuff
I blacked out my front turn signals and removed the silver cover off the front and rear bumper.
Old Oct 30, 2008 | 10:24 AM
  #3107
Klietable's Avatar
It took me longer than others, because I really took it slow. I spent the entire day on Sunday working on it. But it looks great!
Old Oct 30, 2008 | 11:54 AM
  #3108
scottrock's Avatar
Broke the tc linkage. right where the cable attaches to the lever on the tc, *pop* came right off with a broken plastic bushing. Left me in neutral with tc lvr flopping back and forth. Rigged it up, drove to dealer and part is now on order.
Old Oct 30, 2008 | 01:26 PM
  #3109
Hammerman's Avatar
Well Katemcy TX was a blast last run of the year, scrubbed off a bit of rubber on my tires. My JK did as well as some of the other jeeps out there, well in most cases much better. I did more recovery for others than I needed TJ's (5) JK's (0). This was only with stock 32 in tires with an OME HD lift kit. What a good run. I'll try and get more pictures together for the event. I didn't take my JK on the water fall if was fun following the stream down to the end. oh yeah what I did to my JK I seem to rearrange the back tail gate a bit.
Old Oct 30, 2008 | 02:11 PM
  #3110
igmoo's Avatar
Default OME lift
i added the OME lift from Northridge. thanks
