Old May 13, 2013 | 02:49 PM
  #31921
Stephane87's Avatar
Originally Posted by germain
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=457471"/>I don't like stock lights, and the holes and body contour do not work with round LEDs, so when I saw these at a hot rod swap meet, I realized they were the ones( 65 Mustang lense and bezel are all you need). Took taillights off, cut away all excess plastic from bucket (retain the mounting screw areas) with fixture and wiring, then mounted them inside the body. Only wiring change is a wire side to side for the backup light, seen below license plate. I still need to add one on the pass. side and the added wire goes away.
Also you may note the missing center brake light. I cut the bracket down so the light is visible when the brake is on, but not visible otherwise. The main reason for this is the glare in the rear window left me no visibility to the rear when backing up and applying the brake. The glow in the spare tire is very noticeable and can be seen with my tire mount bike rack in place.
Pictures please......
Old May 13, 2013 | 04:12 PM
  #31922
Ssdudas's Avatar
My buddy had to trade in his JK this weekend he gave me his bumper and his cold air intake before he traded it in.
Old May 13, 2013 | 04:27 PM
  #31923
jeepchief's Avatar
Originally Posted by JKbender
I have been thinking of doing the DIY disco mod. What size pin did you need to get? Where did you buy it from?
got everything at Menards. The pin is a little loose but anything bigger would barely fit and wouldn't be easy to take out when you disconnect. I also got grade 8 washers
Old May 13, 2013 | 04:34 PM
  #31924
GoinCamando's Avatar
Personally, I'd just remove the nut, keep the washers and drill a hole thru the factory bolt and add the clip pin.
Old May 13, 2013 | 04:50 PM
  #31925
Originally Posted by Cali Cosmos
Type in "2011-2012 Jeep A/C vent removal" on youtube...I just did it last week.
Remove the bezel and they unlock on the rear twist out to the front.
View From the rear
Unlock then twist.
The rest is obvious.
Old May 13, 2013 | 05:24 PM
  #31926
Farnham's Avatar
Added some teraflex advertising in anticipation of my 2.5" lift that came in today and should be on within the month
Old May 13, 2013 | 05:56 PM
  #31927
Rico's Avatar
Originally Posted by Mike2189
Attachment 457456
Black out markers and did a real light coat on the tail lights.
Good Job !!! I snapped the clips trying to put mine in...then snapped the fronts also.......are yours the recons? I was so pissed ..had to put the oems back in and now I have them sitting here ...I may switch the body of the oems with the recons.
Old May 13, 2013 | 05:58 PM
  #31928
RenegadeUL13's Avatar
Rock rails added!
Sent from my DROID RAZR using Tapatalk 2
Old May 13, 2013 | 06:13 PM
  #31929
rjaranilla's Avatar
Originally Posted by RenegadeUL13
Rock rails added!
Hi is your soft top stock or the bestop black twill? If so where did you buy it from? Thanks
Old May 13, 2013 | 06:17 PM
  #31930
AKJK2012's Avatar
Replaced the jeep logo with a black one
