#3291
Put the Rubicon on jack stands, found all the areas that have had the paint scraped off the skid plates , used a wire wheel cleaned up the rust areas and painted.
#3293
Rubicon Gears
Had 5.13 gears installed. Still in the 500 mile break-in process.
2007 JK Rubicon, 2 door
3" Black Diamond Lift
Rancho Shocks
Front Adj. Control Arms
Rear Adj. Control Arms
JE Reel Front & Rear Driveshafts
M/T Wheels, 17x9
35" BFG KM2 Tires
Superior 5.13 Gears
LOD Front & Rear Bumpers
8K, Milemarker Winch
Rancho Shocks
M/T Wheels, 17x9
35" BFG KM2 Tires
Superior 5.13 Gears
#3295
Top down, doors off for the weekend, and hit the trails. Also, installed a driver side mirror (cheapy euro thing from autozone).
#3297
Finally put in the Silverstar H13 bulbs in the headlights.
I wouldn't bother buying these, you can hardly notice any change.
I even did one side first and you can see a slight difference, but that is it.
Waste of $$ imo
Waste of $$ imo
#3298
Just put the doors back on, went to storage, pulled out the hard top, removed soft top, put the soft in storage, and hard on Jeep.
Now I have doors and hard top on for the "winter"
Going to have to touch up the hard top a little as it was a TIGHT fit in the storage. Heh, it took some work to even open the door higher than a foot to get in there...
#3299
***erator
Blew another front shock and broke the rear track bar bracket. If the bracket is not covered under the lift kit warranty i will buy a new adj. track bar and get rid of the bracket.
#3300
Tire Rotation threw the spare in the mix too. JKS rear trackbar brace (welded) Teraflex Rear trackbar drop bracket improved handling and suspension alot. Should have done this when I put the lift on, procrastinations a bitch tho.
