Old Aug 3, 2013 | 10:51 AM
  #34151
Halfpint's Avatar
Did the body lift and cut the bumper ends. Used RC covers on the bumper and body lift. 2.5 Teraflex coil lift coming soon.
Old Aug 3, 2013 | 11:03 AM
  #34152
Tooadvanced's Avatar
Originally Posted by JKTrails
New powder coated d-rings and winch hook. Also installed a new Spiderwebshade. The shade is great and stays on under the Freedom Top.
You know what's funny with spiderweb shade. Still gotta latch the panels together and web is in way. Its an awesome product but makes it a little harder to put hardtop back on
Old Aug 3, 2013 | 11:28 AM
  #34153
GoldenEagle's Avatar
Just undo the bungee at the driver's door and reach through to the middle. You can reach all the others without taking bungees loose.
Old Aug 3, 2013 | 11:51 AM
  #34154
jlfuksa's Avatar
Dipped cowl and corners, wasn't sure how'd it look but I likey
Old Aug 3, 2013 | 11:54 AM
  #34155
amick218's Avatar
Don't use the two up front just the one in the middle.
Old Aug 3, 2013 | 12:45 PM
  #34156
smartJK's Avatar
My shift bracket broke, so I drilled out those plastic record and put these bad boys on. What do you think?
Old Aug 3, 2013 | 01:32 PM
  #34157
bigmike17's Avatar
New Champion Double Platinum spark plugs at 61k.. runs much smoother. Check out the broken one...
Attachment 484911
Attachment 484912
New water pump, drive belt and thermostat.
Attachment 484913
Then a test drive!!!!
Attachment 484914
Attachment 484915
Muddy as heck on the inside...won't do that with doors off again!! Pressure washed it with my buddy when I got home.
Old Aug 3, 2013 | 03:59 PM
  #34158
lone*krwler's Avatar
Got a new jack and mounted it to the hood.
Name:	jk hi lift.jpg
ID:	484949Click image for larger version
Name:	jk hi lift 2.jpg
ID:	484950Click image for larger version
Name:	jk hi lift 3.jpg
ID:	484951Click image for larger version
Name:	jk hi lift 4.jpg
Old Aug 3, 2013 | 04:06 PM
  #34159
kbp810's Avatar
Replaced my old arb compressor with an ARB twin using the Carolina Metal Masters passenger seat mount
Compressor into 2 gallon air tank, then up to a multi port manifold mounted where my old compressor used to be
Old Aug 3, 2013 | 04:16 PM
  #34160
stoops's Avatar
Installed the Teraflex leveling kit and Poison Spyder wheel adapters in preparation for new tires this coming week.
