Old Dec 1, 2008 | 09:04 AM
  #3411
jeepin08's Avatar
Originally Posted by 07rubisteve
Installed the HID kit to Headlight and Fogs....so bright compared to Stock.....sorry no before pics, or night shots yet...Totally the way to go...When I took my OEM bulbs out, I realized why they were so bad....all the casings of the bulb were sooo black, they looked burnt....I am surprised they even produced any light..
The HID Kick A$$!!!!
One shot while driving in Vancouver...you can see how bright they are
How much does it cost to do the HID kit? is it just replacement bulbs or how does it work?
Old Dec 1, 2008 | 11:57 AM
  #3412
07rubisteve's Avatar
Originally Posted by JulietKilo
Nicely done, where did you buy them and how much? I have been contemplating this for a while.
JulirtKilo,Mr. RonGilbert, & Jeepin08, The HID kit is from www.hidoutlet.ca
I got each kit for $200 Canadian plus tax. ($400+tax) I had to buy 2, one for the headlights, and 1 for the fogs. The kit comes with wiring harness, waterproof ballasts, HID bulbs. You can change HID bulbs to whatever power you want. I went with the 6000K, as I was told they were the most efficient and produced the best light. The higher power bulbs the more color blue tint, look cool but are not as efficient in producing light.
Each bulb has its own ballast. I originally purchased the high/low kit, but the JK computer did not recognize it, and would not allow it to go to high beam. Rubicon_fan has a similar problem with his High/low kit. The low beam works flawlessly and is awesome. Therefore, my supplier gave me HID bulbs that have a second bulb along side it that is a high beam halogen. This works, but the low beams are actually much better.
My lights are so bright now, and haven't seemed to bother any oncoming traffic yet. I have the drivers side headlight pointed more towards the ground, and the passenger side is up and out. Seems to work great so far. I don't think I will ever go back to halogen on any vehicle after having this I will switching my Cobra over to this this winter for sure.
Well worth the money spent...you can actually see things now...
I am getting 6 inch HID Offroads for the windshield this month...and they are stupid bright....will post when i get them.
Steve
Old Dec 1, 2008 | 01:46 PM
  #3413
Roxzilla's Avatar
Finally got rid of that damn plastic air dam under the front bumper. Had to get a bit thuggish with those plastic screws. - hate those things.
Old Dec 1, 2008 | 02:28 PM
  #3414
Kramer's Avatar
Default I put mud on it :)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Dec 1, 2008 | 02:42 PM
  #3415
MMM...Mud's Avatar
I used my spare for the first time...
Old Dec 1, 2008 | 03:20 PM
  #3416
bmcqueen's Avatar
I added ceramic brake pads....got tired of the squeeking and the dealer was giving me the run around.
Old Dec 1, 2008 | 03:56 PM
  #3417
KimmersJK's Avatar
So converting to american dollars.....you can get 7 lights for that.......
Old Dec 1, 2008 | 04:05 PM
  #3418
Jeeper-Chris's Avatar
6 months ago it was the other way around! Crazy markets...
Back on topic, I've only had the JK 1 month now:
Added Long range slim lites
Added locking hood latch
Added locking gas cap
Removed subwoofer for more storage
Reversed the mirror
Ordered rugged ridge diff covers (as a start)
Definitely enjoying this vehicle. First Wrangler, and I got to say I like it.
Old Dec 1, 2008 | 05:05 PM
  #3419
In each Kit there are 2 bulbs, 2 ballasts, wiring etc.. Since our Canadian has dropped big time, it would be much more affordable for you guys South of here to buy this...
Old Dec 1, 2008 | 08:26 PM
  #3420
meljr's Avatar
Default Hi Lift mounted on OR-Fab carrier - replaced Steps & Evap
I finally got around to mounting my 4' High Lift Jack on the OR-Fab rear tire and Jerry can carrier. One trip to the hardware store for two wing nuts,
a couple of regular nuts, 2 lock washers, 4 flat washers and 1' of 3/8"x16 threaded rod (cut in half -- the carrier already has the holes tapped).
I also used a Daystar isolator to keep the handle from rattling.
This is what my formerly pristine Sahara Side Steps looked like after the Halloween
Poker Run:
These are the Mopar Accessory Enhanced Rock Rails I installed to replace the Sahara
Steps:
My dealer sold me the Enhanced Rock Rails for about $480 (they list for a little less
than $600) -- but someone had robbed the parts kit containing the bolts, hex
nuts, washers and the all important U Nuts. The dealer was willing to order the
missing hardware (Mopar part number for the M8x1.25 U Nuts is 06101833), but
we located essentially the same part (Balkamp 665-1304) at the local NAPA store, so the dealer just
bought me a set and we called it even. I had used nuts duct taped to washers to
install the Sahara Steps, but now I have the right stuff!
Finally, I replaced the Evap Canister I totally destroyed and ripped off the JK during
the Halloween Poker run. The canister cost about $31 and the white sending unit,
which was also trashed, was a little more than $8.00. Eventually -- like before I go
wheeling at Brown's Camp again, I will relocate or shield the Evap Canister, but for
now, I just replaced it.
I found it was easier to remove the bracket (3 16mm bolts)
first and then slide the Canister into the three tabs on the bracket. Slightly bending
the locking tab located by my finger down after the canister has been slid into the
bracket, will keep it from rattling.
