Old Oct 20, 2013 | 08:12 PM
  #35941
TURTLECON's Avatar
I really really want my 35s mounted...
  #35942
big dr's Avatar
This weekend I had my fab guy install some King bump stops in the rear. The are pressurized at 180#,,, no more bottoming out in the rear!! I also put in the PSC high volume steering pump. Now the PSC Hydro Assist works much better! Also played with the coil overs. Adjusted the slide stopps down to the point where I'm almost riding on the secondary spring. Much better!! Ill try to post pics of the bump stops soon!
Old Oct 20, 2013 | 08:42 PM
  #35943
meep97's Avatar
Attachment 506663
Looks like you mounted a light bar on it
BTW, those are some sexy tires!
Old Oct 20, 2013 | 09:07 PM
  #35944
bombout800's Avatar
Originally Posted by BRUT4CE
Went ahead and reworked the rear tire carrier to have lateral support and more finished look....
Easily one of the sickest rear setups on a jku! Respect
Old Oct 20, 2013 | 09:10 PM
  #35945
BRUT4CE's Avatar
Former Member
Thanks.
Old Oct 20, 2013 | 09:17 PM
  #35946
FlexyJK's Avatar
How much for one of these??
Sent from my SM-N900V using Tapatalk
Old Oct 20, 2013 | 09:24 PM
  #35947
BRUT4CE's Avatar
Former Member
The tire carrier will be removable and have clamps on roll bars versus the flanges I'm doing on mine.
That's the plan the other one I'm currently working on will bolt in as well but the tire will sit higher and be able to fit with soft top and hardtop on. I did mine this way because of rack and getting ready for desert season (johnson valley) kept the weight low and over the axle for body roll and spring unloading on extreme angles....
So no idea yet looks like there will be 2 versions coming out.
will require drilling (6) 1/2" holes in the rear bed and contours the storage bin so its totally usable.
Old Oct 20, 2013 | 09:27 PM
  #35948
MrChuckles's Avatar
I really really want my 35s mounted... <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506663"/>
I love the look of those. I'm still debating either going with those, or the same that I have when I step up to 37s. I'm running 35" Mickey Thompson baja MTZs right now.
Old Oct 20, 2013 | 09:32 PM
  #35949
FlexyJK's Avatar
Yours looks sick. But I like the idea of being able to put the soft top on and had a similar thought in mind about putting it back there. I have the roll bar clamps already just need a welding mastermind to finish.
Old Oct 20, 2013 | 09:56 PM
  #35950
jeep_creep88's Avatar
Fixed the plate holder I broke on the weekend and installed new factory headlamps
ID:	506667   Click image for larger version
