Old Jan 2, 2014 | 11:15 AM
  #36971
Jpsinger's Avatar
Installed the Spyder brawler II rear bumper received over the holidays...
Old Jan 2, 2014 | 11:28 AM
  #36972
Cam36's Avatar
I installed my brawler 1! Lol
Old Jan 2, 2014 | 12:21 PM
  #36973
VASYLfromUKRAINE's Avatar
what kind of backup light you use?
Old Jan 2, 2014 | 03:36 PM
  #36974
Jpsinger's Avatar
Bumper is the 2.5" spyder led and on the tail lights rigid sr-m back up light kit.
http://www.rigidindustries.com/led-lighting?f[0]=field_product_family%3A9&f[1]=field_optics%3A102&f[2]=field_product_family%3A1528
Old Jan 2, 2014 | 04:02 PM
  #36975
BrowniesJK's Avatar
Originally Posted by Pghchamp
http://youtu.be/OWVCbc1y15E Yesterday's New Years ride
Really cool trail
Old Jan 2, 2014 | 04:55 PM
  #36976
nobndry's Avatar
Ordered some KC led headlights
Old Jan 2, 2014 | 05:06 PM
  #36977
donfmorrison's Avatar
Installed the JeepSWAG Stealth Hi-Lift Jack Mount. It's mounted at the top of the rear roll cage. Also put in the quick fist mounts and 4 fists. I haven't found any writeups on this one, so I'll do one of those soon.
Old Jan 2, 2014 | 05:17 PM
  #36978
BRUT4CE's Avatar
Former Member
So made some rear lower control arm mount pockets to cut 1.5" off bottom and move shock up while adding a skid.
I can make em with bolt holes but did side cutouts on mine to to go around the bolt and reduce e weight since the rear control arm bracket is still what's welded to axle...
The small cut out parts are for front shock relocation brackets they take shock out 1.5" up 1.3" and rotate the shock end 90*.
So tomorrow is cutting day and all the mounts will be redone and modified...then adjust bumps and go put it on the wall for flex and check. Getting it dialed for the 16th annual superstition run this month...
Have a spare rear axle sitting here so started making stuff on it....
Old Jan 2, 2014 | 08:07 PM
  #36979
Acer343's Avatar
I installed a rc 3.5 lift, quick discos, duel steering stabilizer, and 4 rigged ridge lights
Old Jan 3, 2014 | 06:02 AM
  #36980
kylelever's Avatar
Installed a Smittybuilt GEAR tailgate cover last night.
