Old Jun 14, 2014 | 09:46 AM
  #40011
Bubbacon's Avatar
Mounted my Carolina Metal Masters grab bar, then added my RAM mount to it for my ipad mini so i can map and trace trails.
Old Jun 14, 2014 | 11:09 AM
  #40012
robsjeep9's Avatar
JK-Forum Ambassador
Removed my simulated Mickey Thompson aluminum bead lock rings too banged up from playing on the rocks and my trip to Moab.... Time to replace with Fabbed up steel rings.
Also picked up some Grabars front and back painted them yellow.... These things are solid!!
Canada, Germany and Mexico flags on jeep for world cup soccer
ID:	559557   Click image for larger version
ID:	559558   Click image for larger version
ID:	559559   Click image for larger version
ID:	559560   Click image for larger version
Old Jun 14, 2014 | 12:35 PM
  #40013
AF_SGT's Avatar
Installed the trektop nx this morning
Old Jun 14, 2014 | 01:17 PM
  #40014
Pepperbrooks23's Avatar
Originally Posted by lone*krwler
Thanks! I used a Platinum Burner halogen light kit you can get at Walmart for about $18. The mounting location is just below the fender next to the grille. The installation is very simple and straightforward , I just followed this write-up. http://wayalife.com/showthread.php?4...ation-Write-Up The ground wire to the switch was too short, so I had to lengthen it. I placed the switch next to the passenger side speaker because I don't have a rocker switch panel.
Nice! I'm going to install some here soon and have been trying to decide on the best set up to go with.
I installed some LED strips in the back so I can see my tools at night. But instead of a rocker switch that could accidentally get clicked on when I have gear piled in the back, I went with a water proof flush push type switch. It also glows green when clicked on.
ID:	559579   Click image for larger version
ID:	559580   Click image for larger version
Old Jun 14, 2014 | 01:26 PM
  #40015
Here are a couple more pics of the set up for my cargo lights. I'm thinking of going with the same switch for ground lights, but maybe on the A pillar... The last pic is one I saw here on the forum... I think....
ID:	559583   Click image for larger version
ID:	559584   Click image for larger version
Old Jun 14, 2014 | 01:27 PM
  #40016
Frakesmotorsports's Avatar
How makes those grabars those are nice ?
Old Jun 14, 2014 | 02:03 PM
  #40017
olram30's Avatar
Grabars....
Old Jun 14, 2014 | 02:42 PM
  #40018
JK-Paul's Avatar
Originally Posted by Stephane87
Where do you find the number????
https://www.facebook.com/jeep/app_732490086785695
Old Jun 14, 2014 | 03:19 PM
  #40019
puffy's Avatar
I installed my Comet CA2x4SR 2m/70cm antenna. I brought the transmission line into the cabin but haven't put a connector on it yet.
Old Jun 14, 2014 | 03:52 PM
  #40020
TreyJK's Avatar
Where did you get the mounting plate? Or did you fab it up? I used to have mine between the back glass and spare tire but I tore it off last weekend... Possibly looking at mounting it the same place as yours.
