Old Mar 22, 2015 | 06:51 AM
  #43001
jeepguy91's Avatar
Originally Posted by DAVE21
Dalton here
Salem here
Old Mar 22, 2015 | 08:27 AM
  #43002
brycesaunders3241's Avatar
Originally Posted by D_engel
I made it. It is similar, but made some changes to better suit my likings
for your tire carrier, did you fab up the brackets that mounts it to the body? Or did you purchase through genright or another company? Thanks
Old Mar 22, 2015 | 08:57 AM
  #43003
Shoupadupe's Avatar
Originally Posted by BIGTARS
Yeah took it off. The mesh is really nice but I was just wanting the 7 slots back. I'm still going to hang on the other grill for now.
You ever decide to part with it, send me a msg
Old Mar 22, 2015 | 09:25 AM
  #43004
D_engel's Avatar
I made the brackets as well from 3/16" rectangle tubing
Old Mar 22, 2015 | 09:54 AM
  #43005
doc5339's Avatar
Veteran: Navy
Changed Air Filter with MOPAR.
Changed Gear Oil in both Front & Rear Diffs with Valvoline SYNPower Full Synthetic 75w90.
Changed Transfer Case Fluid with AMSOIL Universal ATF (ATF+4 compatible).
Changed Manual Transmission Fluid with AMSOIL Synthetic Syncromesh Manual Transmission Fluid, an it actually shifts much smoother now!
Researched the cap out of Radiators and OAT Coolant Antifreeze since my OEM Radiator core is cracked.
Old Mar 22, 2015 | 10:21 AM
  #43006
14Sport's Avatar
FWIW, I like the slots better.
Old Mar 22, 2015 | 11:47 AM
  #43007
RyanBauer's Avatar
Chopped fenders and custom fab'd stinger!
Old Mar 22, 2015 | 11:52 AM
  #43008
Jp3792's Avatar
Installed spot lights, and floor lights i wired them into the dimmer switch. Also installed back up lights
Old Mar 22, 2015 | 12:50 PM
  #43009
Chapman89's Avatar
Installed a pair of Skidrow lower control arm skids that I picked up gently used. After some sanding, primer and two coats of paint they're like new!
Old Mar 22, 2015 | 03:50 PM
  #43010
Bubbacon's Avatar
Installed my RIPP Supercharger (alone!). Took about 14 hrs total. Install was pretty straight forward - but a lot to do! Man, it really gets up and goes now ('11 JK Rubi).
